20 Most Recent
Acoustic Audio AA5104 5.1 Home Theater Surround Sound Speaker System Questions & Answers
Acoustic solutions radio dock instructions
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them from, and they have online it was very good manual.
Go ahead, I bet.
Boston Acoustic 5.1 surround, auto-on subwoofer. ZD3 diode fried brown, system works without diode, do I need to put in a new diode? If so, which direction is +.
Re polarity - the diode should have a band nearer one end.
This band is the cathode.
Usually labelled k in schematics.
The un-banded end is the anode.
Usually labelled a in schematics.
On a standard rectifier diode:
The positive + supply enters the diode at the anode and exits at the anode.
However, the component's ID is ZD3, which tells me that this is a Zener diode.
A zener diode is connected opposite polarity to a standard rectifier diode, as it only conducts when reverse voltage from k to a exceeds a pre-determined level.
This is probably part of a voltage regulation or voltage clamping circuit.
ie: when voltage on 'k' line which is positive goes above 'X' volts the zener will conduct, shunting voltage to ground or another part of circuit.
So on ZD3, band is +.
A new diode is advisable, as it serves as over-voltage protection.
The caveat is what voltage rating of zener diode you will need.
A schematic of the sub will be needed to know this....
