20 Most Recent Frigidaire FDB1502RG Built-in Dishwasher Questions & Answers
what can cause the spray arm to get burned? is it too hot water in the water heater or the heating element ?
Frigidaire... | Answered on Apr 17, 2013
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
Frigidaire... | Answered on Mar 27, 2013
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Frigidaire... | Answered on Feb 20, 2011
Try using a dishwasher cleaner. ou can buy these atyout loca supermarket.
Frigidaire... | Answered on Sep 18, 2010
Check the timer control.
Frigidaire... | Answered on Sep 16, 2010
Reset the dishwasher by switching the breaker off for a couple of minutes. this will reset the dishwashers electroincs. If nothing else is wrong this should do it.
Frigidaire... | Answered on May 16, 2010
under the bottom right corner is the electical tie in connections if you are able to use a voltage meter and can detect if you are getting power to the machine. if you are unable to do this i suggest you call a technician because if you have power going to the machine then you would have a control problem a end up having to replace the control
Frigidaire... | Answered on May 01, 2010
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Frigidaire... | Answered on Mar 30, 2010
Press and HOLD the lock button down. It toggles the lock feature when you hold the button down. The lock light went off and the unit works again.
Frigidaire... | Answered on Dec 19, 2009
The waste line from the dishwasher should connected straight to the garbage disposal. there is a hole in the side where it fits. Be sure to knock out the plug in the disposal, or the water will back up and stay in the dishwasher.
Frigidaire... | Answered on Jun 22, 2009
Installed vent? Dishwashers drain directly into the sink drain line. Drain can be installed in cross over between sink drains or on line from sink drain.
After you turn off the power to your dishwasher, you can inspect the dishwasher with a flashlight to find where the melting happened. If it is near the circle that is the heating element, you can suspect the timer froze during the drying cycle.
But also open things up and look for shorted/melted wires (in the door panel and under the dishwasher.)
No matter what you find, if you have proof of purchase for your dishwasher, I would press for repair/replacement from the manufacturer.
Good Luck!
Frigidaire... | Answered on May 04, 2009
Frigidaire FDB1502RG Built-in Dishwasher Logo
Popular Tags
32 questions posted
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
frigidaire dishwasher fdb1500lfco not
  • Dishwashers
