20 Most Recent Whirlpool 24 in. Portable Dishwasher Dishwasher Questions & Answers
2answers
We just bought a used
There is a rubber washer that fits in the faucet before you put the adapter on. That washer is probably missing.
7/26/2021 2:06:07 PM • Whirlpool 24 in.... • Answered on Jul 26, 2021
I need the steps to change the hose assembly on my
Hi, I found this video on You Tube, regardless of manufacturer, the procedure is the same. Click on the link below. GE WD24X10066 UNICOUPLE ASM PartSelect
6/26/2017 7:55:58 PM • Whirlpool 24 in.... • Answered on Jun 26, 2017
How to replace tub in whirlpool DU811SWPQ0
Its easy to do. The out cabinet comes off and the components get switched over to the new tub. Before you do anything. Check your warranty. Many of the whirlpool tubs are warranty for life and will be replaced free of charge for a defect in the tub. IF you cannot find your booklet call whirlpool directly
5/7/2014 12:47:05 PM • Whirlpool 24 in.... • Answered on May 07, 2014
0answers
Pump on dishwasher not pumping
Replace the pump. It's gone out
2/22/2013 1:23:03 AM • Whirlpool 24 in.... • Answered on Feb 22, 2013
WHIRLPOOL PORTABLE DISHWASHER LEAKING FROM
Hello, gm I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>> http://home.howstuffworks.com/dishwasher.htm Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike http://beta.fixya.com/users/mc1bean
10/27/2011 8:23:51 PM • Whirlpool 24 in.... • Answered on Oct 27, 2011
Can I splice an extension
Yes.
1/10/2011 12:48:54 AM • Whirlpool 24 in.... • Answered on Jan 10, 2011
My portable dishwasher runs a complete cycle
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most
4/9/2010 5:19:47 PM • Whirlpool 24 in.... • Answered on Apr 09, 2010
Dishes smell like fish
   Hi, I've been scanning this for awhile as I have this problem on and off. I have watched what I have been cooking and have come to the conclusion it's to do with eggs.  I always noticed it when we had eggs ( they are fed with ground up fish) so changed to vegetarian  fed  chicken eggs and problem got better, I only notice it now if I use a salad cream or mayonnaise type products with egg added in the ingredients and I hand wash these away from all other items.  I have noticed many comments on hygiene, but if you have this problem you become a cleaning nut trying to get rid of it. I always clean with vinegar and bleach and it did not work with this one. Hope this helps
12/6/2009 10:19:23 AM • Whirlpool 24 in.... • Answered on Dec 06, 2009
2answers
The dishes are coming out all cloudy and seem to
Be sure to use a good quality detergent or tablet with rinse aid built in... but before that I would go buy a dishwasher cleaning solution. These are usually in a bottle and you just sit the bottle in the dishwasher by itself (with no other dishes) and run a normal washing cycle. The cleaner will clean the inside of the dishwasher, including the drain area and help produce cleaner dishes thereafter. This should be done every 3-4 months as standard.
8/22/2009 3:36:52 PM • Whirlpool 24 in.... • Answered on Aug 22, 2009
Cloudy glasses and silverware
use product called lemme fresh and jet-dry use the walmart power soap only and the only thing i recommend to remove the cloudyness is citric acid at any pharmacy you have to ask for it use rubber glove wash by hand if it come off you in great shap if not its call etching and they are destroyed never use liquid soap for dishwasher harder to break down and do not choose the heating cyc it bake the soap on
8/20/2009 11:24:54 PM • Whirlpool 24 in.... • Answered on Aug 20, 2009
I want to register my purchase and enter the 90
Go to the Whirlpool website and click on the "Register your product" tab. This will bring up the registration screen. You'll need the model and seriali number- they're probably located on the side of the door gateway-printed on a lable. It will probably auto-enter for the prize giveaway.
7/22/2009 2:38:58 PM • Whirlpool 24 in.... • Answered on Jul 22, 2009
Stuck on clean light always flashing
There is something jammed in either the arm or blade that is setting off the code.
7/9/2009 11:36:44 AM • Whirlpool 24 in.... • Answered on Jul 09, 2009
My Whirlpool Gold GU1200XT series dishwasher does not have Heated Dry button. What button I should press?
Sani Rinse is your only option mentioned here in the manual. This heats everything to 160'F and evaporates the water. https://www.manualslib.com/manual/191224/Whirlpool-Gu1200xt.html?page=9 ..
9/28/2021 9:16:23 PM • Whirlpool... • Answered on Sep 28, 2021
Whirlpool 24 in. Portable Dishwasher Dishwasher Logo
30 questions posted
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
portable dishwasher runs complete cycle
  • Dishwashers
