20 Most Recent KitchenAid KUDK03ITBK Built-in Dishwasher Questions & Answers
Put the tablet in the bottom of the washer ,do a wash cycle,if the tablet is used up the washer is not releasing the tablet till the end of the wash, if the tablet is still there the water is too hard or the tablet is faulty.
KitchenAid... | Answered on Nov 29, 2017
Maybe that is a bit much... I thought of something else you might check... there is a screen at the bottom of the dishwasher... make sure it is clean so that water can keep recirculating.
The thing about adding water is that if you add the water at the beginning, it is going to circulate for 3 minutes or so and then dump out the water and attempt to refill. Most machines do a couple "rinse off" cycles before the soap dispenser opens and the machine washes the dishes for a long time. So you have to put the water in after you hear the dispenser "pop" open.
I'm not completely sure about the Kitchen Aid, but their might be a way to adjust the time that the water inlet valve stays open at the beginning of the cycle... you'll have to check your manual.
KitchenAid... | Answered on Feb 05, 2017
try it by using a high torck screw driver then the direction for loosening the screw is anticlock wise.
KitchenAid... | Answered on Jul 25, 2012
It's giving you a code in those flashes, and can be found online. Many GE affiliated brands use that system.
KitchenAid... | Answered on Jul 23, 2012
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
KitchenAid... | Answered on Aug 18, 2011
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
KitchenAid... | Answered on Jul 22, 2011
Hello, Thank You for using FixYa. I will be helping you today. Yes i would remove as much as you can you wont damage the heating element. Then run a cycle with heated dry and check after the cycle if you can remove the fest.
Thank You and please rate my answer if it was helpful..
KitchenAid... | Answered on Jun 23, 2011
Hello, Thank You for using FixYa. I will be helping you today.Read this http://kitchenaid-internal.custhelp.com/app/answers/detail/a_id/3854
KitchenAid... | Answered on Jun 15, 2011
Do you hear a humming sound, like the motor trying to run, then stopping for a minute or two before trying again?
Usually, dishwashers run the motor one direction to wash, and the opposite direction to drain, but some use a valve to switch. If you see wires going to a bulky flapper looking part sticking off the side of the pump/motor, you might have a bad valve actuator.
Otherwise, you might have a motor refusing to turn in one direction. You can usually access the shaft from inside the tub by removing the washer arm to get access to the pump impeller. Do not remove the impeller unless necessary, but see if it will turn both directions. Broken glass or pieces of bones or other debris might be interfering with the rotation. If it turns freely both ways, but still won't wash, it is likely you have a bad starter coil on the motor, and will need to replace the motor/pump assembly. These usually have a longer warranty than the rest of the unit, so if yours is less than 5 years old or so, it would be worth checking with factory service.
KitchenAid... | Answered on May 18, 2011
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 ,../,
KitchenAid... | Answered on Mar 23, 2011
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
KitchenAid... | Answered on Nov 12, 2010
heatman101
KitchenAid... | Answered on Sep 30, 2010
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
oi57
KitchenAid... | Answered on Sep 29, 2010
If the model number is correct, you can lock and unlock the controls on your dishwasher by pressing and holding the HEAT DRY button for at least 4 seconds. If these instructions do not work for you, or if your model number differs, please post back and let me know. I hope this helps you.
KitchenAid... | Answered on Jul 07, 2010
Check the float switch, there is a switch under a little cover inside the sump of the unit. It will look like smaller than a can of soda. If you are able to get the cover off (some are glued) then see if the float will move up and down.
KitchenAid... | Answered on Jun 25, 2010
KitchenAid KUDK03ITBK Built-in Dishwasher Logo
67 questions posted
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
white film forms all dishes also
  • Dishwashers
