20 Most Recent LG 50PB4D 50 in. Plasma HDTV Questions & Answers
audio lag is normal for many TV's.
LG 50PB4D 50 in.... | Answered on Jul 04, 2017
LG have a firmware upgrade on thier website for this issues. I did it on mine - worked a treat.
LG 50PB4D 50 in.... | Answered on Sep 01, 2012
If you are in Australia and have no sound on GEM and 7-Mate, follow the instructions here, to update the TV's (LG 50PB4D-AA) firmware. Once done you will receive sound on these channels.
LG 50PB4D 50 in.... | Answered on Nov 26, 2010
yes it is, and yes it can. BUT it maybe a difficult problem to determine if it is intermittent, you will be best served waiting until it fails "Hard On" otherwise it may take some time to find the intermittent fault. http://www.retrevo.com/support/LG-50PB4D-TVs-manual/id/3068bh134/t/2/
user manual above service manual below.
http://www.jordansmanuals.com/ServiceManuals\LG\TV\PLASMA\50PB4D\50PB4D%20Service%20Manual.pdf
LG 50PB4D 50 in.... | Answered on May 23, 2010
Off-Air reception (Antenna) of TV Guide comes from a supplier called Rovi (formally known as Macrovision, Gemstar). They have supplied your local CBS affiliate with a TV Guide application known as SCTE 127 or VBI in MPEG. Follow these steps until you have found a solution to the TV Guide - No Information Available.
1. Check to see if your local CBS station is coming in clearly not tiling.
2. Reset your TV Guide through your TV Guide Menu, for more information copy and paste the link below. (What usually works for me is setting up the guide by putting in 99999 for the zip code then answer all other questions. After it says your TV will receive the guide in 24 hours then setup the guide as you normally would with your zip code).
http://www.rovicorp.com/support/13094.htm?link_id=topnav
3. Contact your local CBS affiliate engineer and see if they are having problems with the TV Guide transport stream i.e. SCTE 127 or VBI in MPEG
FYI if you get your service from a Cable TV company they will have to pass this information through their system commonly referred to as Passing PIDS.
LG 50PB4D 50 in.... | Answered on Feb 08, 2010
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
LG 50PB4D 50 in.... | Answered on Jan 16, 2009
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent...
LG Televison &... | Answered Yesterday
Did you know there's a "deep detox" you can do first thing in the morning to burn more fat? And the good news is It only takes 13-seconds! Here it is->>:)w­w­w­.­­­w­­­o­­­r­­­k­­­n­­­e­­­t­­8.­c­o­m->>
LG Televison &... | Answered 3 days ago
It was thrown out for a reason, and probably because it is uneconomical to repair. Take to a repairer for a quotation to fix it.
This explains why, and why you can't diagnose television problems on an online forum. The television sections are really only for help with manuals and remote codes.
Here are similar questions that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ? Or
Turns on and sound works fine, but the picture is distorted (solarized? polarized? not sure what the term is) I replaced the main board, but that didn't fix it.
Or
I have an LG 55LM6200-UE with a dim lower-left. I just replaced both LED strips with no resolution. There is no physical obstruction visible, so this has to be a cable or board problem, right?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work as it should! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what it does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part you put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'NO Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous sellers use it as an excuse to get money for selling items that may, or may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $5 in parts and a couple of hours labour. It's not the fix you want to hear, but it is the best advice.
Andrew - Fixya Moderator
take it in for professional repair, it is by far the cheapest option than swapping out boards that may or may not be faulty. You need all the test equipment and the knowledge.
LG Televison &... | Answered on Jun 25, 2020
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/.
LG Televison &... | Answered on Jun 24, 2020
Here is the value of R405.
It is a 300OHM 5% 1/6W
LG Televison &... | Answered on Jun 22, 2020
If you power on your TV but you do not see the menu options, or any video display - just a black, blank screen, and possibly no audio as well; try the recommended steps below to resolve the issue. Check if the status LED, in front of your TV is ON. ... To confirm, point the TCL remote towards the TV and press any button.
LG Televison &... | Answered on Jun 18, 2020
LG 50PB4D 50 in. Plasma HDTV Logo
14 questions posted
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • LG Televison & Video
Most Popular Question
no sound two channels only
  • Televison & Video
