20 Most Recent Sony HDMI Single Disc DVD Player Questions & Answers
Never realised you needed Audio Cables w/ the HDMI
Sony HDMI Single... | Answered on Jan 06, 2009
possible control board overheating or video board look for capacitors swelling on boards
Sony Televison &... | Answered on Sep 19, 2020
If your Sony remote control is compatible with your RCA TV, it will contain the applicable code(s).
3 blinks is a error code "lamp door not properly closed" but what it really means is the lamp door is warped from heat from the lamp.
The door if removed has a plastic peg on its back side-the peg when door is in place engages a tiny lever behind it----
What to do?
Remove door and engage the lever with something not metal==turn set on and if it comes on you know the door is the issue.
DO NOT LOOK DIRECTLY AT THE LAMP- DO NOT OPERATE SET PROLONGED TIME WITH DOOR REMOVED OR COVERED WITH ANYTHING ELSE==THIS IS ONLY TO SEE IF THE DOOR AND SWITCH ARE YOUR PROBLEM.
SD TECH
Sony Televison &... | Answered on Sep 16, 2020
An almost complete guess that you are feeding digital into a tv that is incapable of processing it.
HDMI is digital only and an adaptor lead won't convert the signal to analogue. Digital to analogue converters are available but how successful they are I have no experience...
Sony Televison &... | Answered on Sep 10, 2020
Battery failure. A new charger won't cure the problem.
Sony Televison &... | Answered on Sep 06, 2020
You can if the Sony remote control contains codes applicable to the LG DVD player
Yes, because both need power :>D
https://www.helpowl.com/q/Sony/KDL40BX420/Recalls/recall/100033
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk03Cs9eajQuHINHoUcbs492lB7acJg%3A1599406698565&ei=agJVX9-EIvKuytMPpO2ViAk&q=Bravia+KDL40BX420+recalls
No a Sony dvd remote can't program a sanyo tv
Sony Televison &... | Answered on Sep 03, 2020
Replacement power supply and/or main board could be defective
Sony Televison &... | Answered on Aug 23, 2020
Use code search on your remote control to find something that works. If a search through all codes stored in the remote control fails, try a different remote control.
Sony Televison &... | Answered on Aug 22, 2020
Sony HDMI Single Disc DVD Player Logo
8 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
no sound no picture
  • Televison & Video
