20 Most Recent
LG 32LC7DC 32 in. LCD HDTV Questions & Answers
I have a 32LC7DC TV.
Getting just a blank white screen and lost all functions to the tv.This problems is the tv Tuner signal board is dying,will be dead.That the board,where the incomming tv broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
We have 2 year old sets in some of our hotels.
These problems can not be taken any pro-active measure to prevent this,because it the tv electronic board call the T-CON decoders board is dying,that why is causing this problems.These problems,will not happen to all the tvs sets in ur hotel at once.So,just take care the tvs that have these problems.
Lg 32 inch lcd on light flashing white but fast
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board.
The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
