20 Most Recent Samsung FP-T5884 58 in. Plasma Television Questions & Answers
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Samsung FP-T5884... | Answered on Aug 18, 2008
Working Online from home and earns more than $15k every month. I have received $17365 last month by doing online work from home. Its an easy and simple job to do from home and even a little child can do this online and makes money. Everybody can get this job now and earns more dollars online by just copy and paste this website in browser and then follow instructions to get started right now.... Click For Full Detail.
Samsung... | Answered 38 minutes ago
If you had sound, the power board was fine. The 'let's try changing this' method of television repair never works. You need the test equipment and knowledge at component level. Take it to an engineer, it is much cheaper.
Samsung... | Answered Yesterday
That indicates a problem with the power supply. If your TV is under warranty, I suggest to contact the manufacturer for a repair or replacement.
Samsung... | Answered 3 days ago
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Samsung... | Answered on Sep 14, 2020
Typically bad inverter board for backlight. I would google "backlight inverter" and your brand for a You Tube video if you are tech savvy. You could try the oven trick (put the board in the oven on a sheet covered with tin foil, (10 minutes at 385 degrees and let cool) but it will smell horrible. This has "fixed" the loose solder on several boards for me in the past.
Samsung... | Answered on Sep 13, 2020
check antenna connections if ok bad control board or interfearance from ac
Samsung... | Answered on Sep 11, 2020
It is due to a connection issue like faulty cables, improper installation, or an issue with a device connected to the TV. It may also be due to improper video output settings that need to be set up properly.
Samsung... | Answered on Sep 10, 2020
Probably a failing power supply. Your voltage readings would confirm that.
Samsung... | Answered on Sep 08, 2020
A black TV screen may just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it could be possible it could actually be your external device and not your TV.
-Reset ALL components by unplugging them about for 5 minutes including the TV. -Be sure all COAX CABLES and HDMI CABLES are tight and properly connected. -If you CAN pull up the TV MENU when you have the black screen, update your TV's firmware to be sure your TV is up to date and rule out the TV as the problem.
Samsung... | Answered on Sep 06, 2020
Samsung FP-T5884 58 in. Plasma Television Logo
8 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
  • Samsung Televison & Video
Most Popular Question
blown picture
  • Televison & Video
