20 Most Recent Pioneer PDP-6010FD 60 in. Plasma HDTV Questions & Answers
Does not turn on. Prior worked but shut off after about 30 min/blue on light flashed. Replaced Y board and now does not turn on but blue light on . Put the old Y board back, still does not turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
1/28/2016 10:55:56 AM • Pioneer... • Answered on Jan 28, 2016
Pioneer PDP-6010fd plasma TV stays on 15secs to 30min then shuts off and the red LED starts flashing twice Would like to know if this is due to capacitor problems on the power board
it could be due to a leaky capacitor not holding it's charge , check them but earth the board after removing mains plug.
12/20/2015 12:03:47 AM • Pioneer... • Answered on Dec 20, 2015
Relay clicks when pulgged in but no power
Main board fault. Contact the authorized service center. http://electronicshelponline.blogspot.com/
6/28/2014 6:36:05 PM • Pioneer... • Answered on Jun 28, 2014
0answers
Update firmware
Be the first to answer 1/25/2014 3:31:47 AM • Pioneer... • Posted on Jan 25, 2014Be the first to answer
0answers
Tuner setup -
Be the first to answer 1/20/2014 3:35:35 AM • Pioneer... • Posted on Jan 20, 2014Be the first to answer
Tv just makes a click noise when pluged in
remove the back and look for any swollen or blown capacitors. it sounds like your power board went out
12/2/2013 1:38:04 AM • Pioneer... • Answered on Dec 02, 2013
0answers
How do I change language to English
Here is a link to a Manual to this TV
1/30/2013 7:36:01 PM • Pioneer... • Answered on Jan 30, 2013
0answers
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
9/22/2012 7:42:13 PM • Pioneer... • Answered on Sep 22, 2012
Problem with Pioneer PDP-6010FD
HelloThe set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
2/22/2012 7:53:19 AM • Pioneer... • Answered on Feb 22, 2012
0answers
I can't get it to power on.
You press menu or you can take the plug out the wall and plug it back in
4/21/2009 2:28:39 PM • Pioneer... • Answered on Apr 21, 2009
Pioneer PDP-6010FD 60 in. Plasma HDTV Logo
27 questions posted
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Televison & Video
Most Popular Question
not turn prior worked but shut off
  • Televison & Video
