20 Most Recent Coby TF-TV3208 32 in. LCD Television Questions & Answers
Colby lcd with short remote range
first replace the battery of the remote with a new one then clean the remote sensor clean any dust accumulation.clean also the remote reciever sensor wipe it with a soft cloth
4/9/2012 4:15:41 AM • Coby TF-TV3208... • Answered on Apr 09, 2012
2answers
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you. If you have the battery details you might be able to get one online.
2/6/2024 10:44:52 AM • Coby Televison &... • Answered on Feb 06, 2024
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps: Turn on the device you want to program. Press and hold the Setup button on your remote until the LED light turns on. Press the device button (TV, DVD, CBL, etc.) for the device you want to program. Press the CH+ or CH- button repeatedly until the device turns off. Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully. Otherwise, you need to search for the manual for the remote.
11/20/2023 12:12:03 AM • Coby Televison &... • Answered on Nov 20, 2023
How to connect Coby tftv lcd 3229 to wifi
you don't. It is not wifi compatible link to manual copy and paste https://www.manualslib.com/manual/468639/Coby-Tftv3229.html#manual
10/20/2023 11:45:43 PM • Coby Televison &... • Answered on Oct 20, 2023
Coby TF-DVD7005. Forgot password on it for the parental controls.
Question edited for clarity. You need to do a factory reset, but it isn't listed https://www.google.com/search?q=coby+tf-dvd7005+reset+parent+code The default password is "0000" If you want to set it back to the factory default you can email Coby support at [email protected]. ..
4/18/2023 5:49:50 PM • Coby Televison &... • Answered on Apr 18, 2023
Trying to plug in plug in coby tftv3225. Do I use power adapter with red circle? Does it plug into TV in port?
4/9/2023 4:35:08 PM • Coby Televison &... • Answered on Apr 09, 2023
Coby RC-028 under-the-counter television. on local channel 5 the audio is both English and Spanish. How do I turn off the Spanish portion?
If you are hearing both English and Spanish audio on local channel 5 on your Coby RC-028 under-the-counter television, you may need to adjust the language settings. Here are some steps you can try:
  1. Press the "Menu" button on the remote control.
  2. Use the arrow buttons to navigate to the "Audio" or "Language" menu.
  3. Look for an option called "Secondary Audio" or "SAP" (Secondary Audio Program). This option controls the language of the audio.
  4. If the "SAP" option is set to "Spanish," select the option to change it to "English" or "Off" (depending on your preferences).
  5. If there is no "SAP" option, look for a language setting or a similar option that may control the audio language.
  6. Save the changes and exit the menu.
  7. Test the TV to see if the language has been changed.
If these steps do not resolve the issue, consult the user manual for your Coby RC-028 or contact the manufacturer's customer support for further assistance.
2/26/2023 10:17:47 AM • Coby Televison &... • Answered on Feb 26, 2023
I have a Coby TF-DVD5010. Whenever I try to put the charger in. the light doesn't appear
google Coby TF-DVD5010 charger amazon, ebay has them.
12/27/2022 8:50:16 PM • Coby Televison &... • Answered on Dec 27, 2022
How to factory reset my Coby LEDVD1996
Unplug the unit.Wait 30 seconds.After 30 seconds, plug the unit in and turn it on again.
12/18/2022 7:24:42 PM • Coby Televison &... • Answered on Dec 18, 2022
My Coby television has a blue light screen when I try and turn on but nothing else.
It sounds like it has lost its picture Source. Try scrolling through 'Input' or 'Source' buttons on the remote. If it is a fault with the set, this budget brand is not worth repairing. https://www.google.com/search?q=Coby+television
9/1/2022 8:42:06 PM • Coby Televison &... • Answered on Sep 01, 2022
How to install a 55in unit base
Not sure what you're asking "how to connect a unit base to the TV connector"
4/11/2022 12:02:43 PM • Coby Televison &... • Answered on Apr 11, 2022
Manual for COBY 40 tftv4028 lcd
C puedo actualizar me tv coby
8/27/2021 3:45:57 PM • Coby Televison &... • Answered on Aug 27, 2021
Where i can find the coby service center in the philippines
At tophill.
8/11/2021 2:05:40 AM • Coby Televison &... • Answered on Aug 11, 2021
Manual for Coby 224 DVD Player
The manual is all over the internet! Question edited for clarity and move from Office Equipment to the correct one.Coby DVD-224 Manuals ' ManualsLibwww.manualslib.com > ... > Coby Manuals > DVD PlayerCoby DVD-224 User Manual (23 pages) Table of Contents. About DVD. About MP3. About the Player. Front Panel. Rear Panel. Remote Control. Getting Started. Problem Disc Message. Power Management. DVD Mode.COBY DVD 224 USER MANUAL Pdf Download ' ManualsLibwww.manualslib.com > ... > DVD Player > DVD-224View and Download Coby DVD 224 user manual online. dvd/cd/mp3 player. DVD 224 dvd player pdf manual download.COBY electronic DVD Player 224 User Guide ' ManualsOnline ...tv.manualsonline.com > manuals > mfg > 224COBY electronic 224 DVD Player User Manual · 1) Press the "Setup" button. · 2) On the "Down" arrow, press it three times. · 3) On the "Right' arrow, press it once. · 4) ...
3/3/2021 9:27:20 PM • Coby Televison &... • Answered on Mar 03, 2021
3answers
Hi, I have a coby TV, and an AMELY AD-UL036 universal remote, how do I program the remote on my TV?
Use code search on your AMELY URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
12/1/2020 3:46:53 PM • Coby Televison &... • Answered on Dec 01, 2020
I can't find settings for external speakers on my Coby Tv
There may not be any.
11/14/2020 12:52:48 AM • Coby Televison &... • Answered on Nov 14, 2020
Coby TF-TV3208 32 in. LCD Television Logo
4 questions posted
Top Coby Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Mikey
Mikey
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Coby Televison & Video
Most Popular Question
colby lcd short remote range
  • Televison & Video
