20 Most Recent
Sharp LC-42D64U 42 in. LCD HDTV Questions & Answers
Digital audio on lc 42sb45u
They are all wrong. I have this TV. What you think is an optical output actually isn't. The only audio output is coaxial and unfortunately it doesn't work with the HDMI inputs. This TV is a headache if your blue ray player only had HDMI.
Screen
It sounds that the panel is faulty. Anyway, make it confirm. Contact any service technician.
I have a Sharp LC-
you need to check first the power supply board this needs to open the back cover of the TV.The power supply board is where the power cord is connected.there are 3 voltages present on it in order to operate the television.first is 5 v for main cpu,12v for sound and 24 volts for backlight.if one of this voltages is missing TV will not operate normal might as well dead set. use a multimeter to measure the voltages.and post back for your finding and will proceed to further trouble shooting..thank you
Im getting no power whatsoever heard a pop last
The tv power supply board it is dead.That the board,where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering work?Yes,take ur tv aparts.Check the whole power supply board carefully,by replacing all those blown capacitors that are busted open and all those capacitors are dying going to dead like bulging up or puffing up on to it tops.Replacing all those dead capacitors to a those new capcitors,do some modification of the capacitors parts like by replacing it in the same Micro fered,but the voltages should be 5 or 10 higher than those old busted or dying bulging up tops capacitors.By replacing all these dead capacitors and dying capacitors with a higher voltages capacitors.These capacitor to have a better chances to take more heat resistance,while tv be watching for hours of using.The tv should have power and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
My problem is when I
On the Vaio:
right click volume on system tray and select playback devices
select hdmi/ sdip as default and then in the properties deselect dolby
If you don't have those options you may need new drivers installed on your Vaio. Do you have windows xp? The driver can be found here: support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/AR2_Drivers.zip&ip=RAID_AR21.htm
If you have vista the driver can be found here:
support.vaio.sony.ie/downloads/updates/updates.asp?site=voe_en_IE_cons&c=0&s=VGN-AR&m=2418&os=7&osl=1
On the television make sure you are on the right input. Press menu--setup--hdmi setup--audio select--digital
Hope this helps
TV INPUT ON BACK OF TV, GIVE AN ERROR
I recomend that before doing anything else, unplug your TV (from power) for at least 5 minutes and then plug it back in. See if this solves the problem.
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
My tv shuts off
these sets are notorious for bad inverter boards and bad video processor boards.Sharp is well aware of the problem,and will fix the units if you push the issue.
