20 Most Recent Zoom 4360 Questions & Answers
I cant work my,ZOOM GFX-707-guitar,effects
You can find a download link here : http://www.zoom.co.jp/archive/English_Manual/E_GFX707.pdf
I have used these pedals for years, I bought a 2nd as a spare a couple of years ago.
2/5/2011 1:02:51 PM • Zoom 4360 • Answered on Feb 05, 2011
My h2n zoom is not turning on when I slide the power button. It has batteries in and it works when I plug a micro usb into it. please help
Several things you can do, first check out the solder connections on the switches and the Usb input jack, if your still having issues, feel free to contact me, I also offer service and have the best rates around and turn around time is usually 1 to 2 days max and all my repairs come with a full 90 day Cash back guarantee!!!
3/29/2019 10:47:04 PM • Zoom Audio... • Answered on Mar 29, 2019
0answers
Zoom H1 says
What format are you recording in? Recording in the standard resolution WAV format will only give you about 3 hours in total on the 2GB SD card that comes with the H1, whereas lower resolution WAV recording or MP3 recording will give you more hours, more than 34 hours form MP3 at 128kbps.
10/31/2014 11:25:18 AM • Zoom Audio... • Answered on Oct 31, 2014
Www zoom co jp
http://www.pcrepairpro20.com/repair.ph Click 'Start Scan' to scan your PC for errors If errors are found, click 'Next' then 'Repair Now' to Repair the problem You may need to reboot your PC for the changes to take effect.
6/30/2014 10:26:40 PM • Zoom Audio... • Answered on Jun 30, 2014
0answers
Aveis tv
Be the first to answer 5/10/2014 1:43:50 AM • Zoom Audio... • Posted on May 10, 2014Be the first to answer
0answers
0answers
Invalid file
Be the first to answer 9/5/2013 3:01:40 AM • Zoom Audio... • Posted on Sep 05, 2013Be the first to answer
0answers
Data recovery
Be the first to answer 9/3/2013 2:35:48 AM • Zoom Audio... • Posted on Sep 03, 2013Be the first to answer
Want to use 2 wireless
Its going to be dependent on the mics, any high-quality mics should have different channel options, ensuring that they are on seperate channels should fix any interference issues (unless the interference is coming from a different source)
Good luck, if you found this post helpful, please give me a good review :)
5/26/2011 2:53:42 AM • Zoom Audio... • Answered on May 26, 2011
I require an Instruction Manual
try here (midway down page) -> http://www.samsontech.com/products/productpage.cfm?prodID=177
3/28/2011 10:55:58 AM • Zoom Audio... • Answered on Mar 28, 2011
4answers
Hi there. I have a
I'm at a bit of a disadvantage because I haven't seen this brand before, but I deduced from the manufacturer's description and the problem you are having that the track signals do not actually run through the faders, but the fader position is digitally encoded and the number applied to the track data. The lockup at 100 and the random fader position value changes suggest there is a problem with the fader position reading function (probably an analog--to-digital converter). I assume you have already updated to HD16 System Version 1.12 and installed the latest key mapping file for your mixing software. I mention this because perhaps there is an unannounced bug in the older version(s) that causes unexpected fader action on certain operator inputs; there was one such announced glitch in track status indication just for Tracks 1 and 4.
Regarding disassembly:
Can you remove the bottom case with the circuit still attached to the top panel (this is the most common arrangement for mixers)? You may have to remove the hardware from the backside connectors to do so. If this doesn't work, can you separate the pieces far enough to look inside along the right? You may find that the encoder and shuttle assembly are on a separate board that remains attached to the top panel at the first step of disassembly, and there would be cabling from that board to the rest of the unit. It is also possible that these knobs are unlatched from the inside if they don't simply pull off, or they may simply go through big holes in the front panel. I find it hard to believe that anyone would be so mean as to make these one-way, one-time snap-on knobs; the warranty service department techs would complain.
Unless you can use an oscilloscope and multimeter, I'm not sure what you could do inside the mixer other than make sure the cable connectors are clean and properly seated on the fader assembly. You could check the power supply for failing capacitors - perhaps the fader is less forgiving of poor voltage regulation than the rest of the circuit. But then, that is best done with an oscilloscope; failing electrolytic capacitors do not always show externally visible signs of their demise.
2/10/2011 1:02:16 PM • Zoom Audio... • Answered on Feb 10, 2011
3answers
Need to know how to
I just sent you the web-site of a full instruction download for your H4N.
here it is again:
http://safemanuals.com/user-guide-instructions-owner-manual/ZOOM/H4N-_E
c...
2/7/2011 5:31:40 PM • Zoom Audio... • Answered on Feb 07, 2011
All connections correct. Microphones
the exact model for your Zoom Mrs unit is not indicated. so i will refer you to some websites where relevant troubleshooting and possible repair action is indicated. go here and here.
regards
12/1/2010 1:24:07 PM • Zoom Audio... • Answered on Dec 01, 2010
0answers
When I power up my
The zoom seems to be unable to read the card, check that the contacts are clean and possibly try to pull the pins down a little so that they would touch the card better. carefully thought.
make sure there is noting blocking the reader. if that doesn't solve the problem.
The unit may require repairs, the board inside the unit contains very small parts making it extremely difficult to repair at home, and if the board is multilayered (many layers put together) the home repair is completely impossible.
Are you on warranty or outside of warranty?
6/25/2009 4:11:29 PM • Zoom Audio... • Answered on Jun 25, 2009
Zoom 4360 Logo
1 questions posted
Top Zoom Audio Players & Recorders Experts
Ekse
Paul Bade
Muzahura Frank
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Zoom Audio Players & Recorders
Most Popular Question
work zoom gfx 707 guitar effects
  • Audio Players & Recorders
