Check the fuses in your car and on the head unit first, and then check for 12 volts to the power wire and acc wires. Check your ground wire for an open line. If everything checks out, it may be time to invest in a new head unit. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I'll tell ya how I fixed it for 12.99 money back guaranteed if you are not satisfied!
Get timely email assistance from our Top Experts. Receive as many solutions as you need.
It is not the deck that is a load of crap.... I install radios all the time and never had that problem.. You had some idiot work on your audio and he did something wrong. Now my first question is if you have an amp that was later added or put in at the same time. Allot of the time they wire the rca's and the speaker wires in utilizing the harness adapter. Duh,,,, right... Second, they made their own ground which consisted of them tapping into metal under the dash... now think about this that winding noise is probrably from the stereo being grounded to the same place as everything else in your car when they should have used a factory ground.. My suggestion is you paid for it... Make those **** fix what they did until they get it right if they keep fucking up start demanding free shit.... your time is being wasted on their fuck up take what ever you can from those assholes...
You first need to leave the key on and then turn off the radio (hold down "source"). next, press the "func" key. This will take you to the main setup menu. Now, you can use the arrow keys to get to "clock adj" and use the up and down arrows to adjust your hours and minutes. You're now ready to press the "source" key one more time and turn the radio back on.
Changing the language and updating maps on a Pioneer Carrozzeria AVIC HRV22, which typically comes with Japanese language settings, can be a bit tricky, but it's possible. Here's a general guide:
Locate the Settings: First, try to navigate through the menu to find the settings option. It might be represented by a gear icon or a wrench icon.
Use a Translation App or Guide: If you can't understand the Japanese menu, use a translation app on your smartphone to translate the menu options. Alternatively, you can search online for a guide or manual in English for your specific model.
Change the Language: Once you've located the settings menu, look for an option related to language settings (???? in Japanese). Select it and then choose English (or ?? in Japanese). Confirm your selection.
Update Maps: Updating the maps might require accessing a specific section of the menu, typically labeled something like "Map Update" (????). Once you're in that section, follow the prompts to update the maps. This might involve connecting the device to a computer and downloading the updated maps from the manufacturer's website.
Follow On-Screen Instructions: Throughout the process, pay attention to any on-screen instructions or prompts, even if they're in Japanese. Sometimes, the navigation buttons or layout might remain consistent regardless of the language.
Reset if Necessary: If you accidentally get stuck or lost in the menus, there might be a reset button somewhere on the device. Pressing this button will restore the device to its factory settings, allowing you to start over.
If you find it challenging to navigate the menu or if the options are not readily understandable, you might want to seek assistance from someone who understands Japanese or consult a professional who specializes in car audio/GPS systems. They can guide you through the process more efficiently.
The issue you're experiencing with your Pioneer PD-M40 suggests a potential problem with the disc loading mechanism or the sensor that detects the presence of the disc cartridge. Here are some troubleshooting steps you can try:
1. **Clean the Disc Cartridge and Player:**
Dust or debris on the disc cartridge or inside the player may affect proper disc loading. Remove the disc cartridge and clean both the cartridge and the player carefully with a soft, lint-free cloth.
2. **Inspect for Obstructions:**
Check for any visible obstructions inside the disc loading mechanism or around the edges of the disc cartridge slot. Ensure that there is nothing blocking the path of the cartridge as it is inserted.
3. **Check for Proper Alignment:**
Ensure that the disc cartridge is properly aligned when inserting it into the player. Misalignment may prevent the player from recognizing the presence of the cartridge.
4. **Try a Different Disc Cartridge:**
If you have access to another disc cartridge, try inserting a different one to see if the issue persists. This can help determine whether the problem is specific to the cartridge or the player itself.
5. **Power Cycling:**
Turn off the player, unplug it from the power source, and wait for a minute or two. Plug it back in, power it on, and then attempt to insert the disc cartridge to see if the issue is resolved.
6. **Test with the Lid Open:**
Power on the player with the lid open and observe the disc loading mechanism as you insert the disc cartridge. Check for any unusual movements, sounds, or signs of misalignment.
7. **Lubrication:**
If the player has not been used for an extended period, lubrication on moving parts may have dried out. Consult the user manual for recommendations on proper lubrication or contact Pioneer customer support.
8. **Contact Pioneer Support:**
If the issue persists and you've exhausted the troubleshooting steps, it may be advisable to contact Pioneer customer support or seek assistance from a qualified technician. There could be an internal issue that requires professional attention.
Always refer to the user manual for your Pioneer PD-M40 for model-specific instructions and recommendations. If you don't have the manual, you may be able to find it on the Pioneer website or by contacting their customer support.
Question edited for clarity.
Greetings from Mississauga :>D
My research shows it just needs a standard RCA lead to connect. However you realize this is just a standalone CD player and needs an amplifier as well as speakers? It has no amplification of its own, it just puts out an audio signal.
When connected to a Pioneer System Audio Amplifier, the control cables allow you to control the CD Player from the Amplifier remote control as they cable connect to that amplifier. The Line Out connections are for the RCA cable and supply the audio data to the amp.
https://www.google.com/search?q=PD-F605+cables
You just have one small part of a composite audio system.
Regarding speakers, most are 8 ohm. you can spend $50 used or $60,000 for Bowers and Wilkins Nautilus. I have a pair of Wharfedale Linton speakers that I bought from the UK factory that you can have for $450 CDN :>) Top of the range.
...Watch the videos with black squares on YouTube.
