Ensure that the stereo is powered, check cable and connection. Disconnect battery for one minute and try again. Before disconnecting the battery ensure that you have anti theft code if required. If
that does not work, disconnect battery again, and try repeatedly
pressing the eject on changer while someone else connect power back.
If
that does not work the unit must be taken apart to remove the disk.
Disassembly involves removing external cover, and usually it is not too
complex.
I think this is an old Blaupunkt where the code cannot be calculated using the serial Number.
It will require specialist advice
Try asking here for free advice....CLICK HERE
Mention FixYa
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
Hi I have suzuki ignis too and I have problem with radio code too...but I am from slovakia and my english is so amynous...and I dont understant this web side (www.ukbookshelf.co.uk) its free ?
39101-86G1
ID: 39101-86G1.......like gedwards80 on the top :)
Check your cable connections for the TV and the receiver or for the video devices.The signal that is being received from your TV might be weak or poor.You will need to contact your service provider to improve the signaling strength for the TV..
