20 Most Recent
JVC KD-G421 CD Player Questions & Answers
JVC KD-G421 - cannot access menu to add ext-in
The JVC KD-G421 only shows the option to change EXT IN from the CD changer to EXT IN when the current source is FM, AM or Disc . See the following page at ManualsLib:
https://www.manualslib.com/manual/81662/Jvc-Kd-G421.html?page=15#manual . Assuming the J-Link cable that you added is the KS-U57 or KD-US58, the unit is still looking for (and not finding) the CD changer. Press the SRC button repeatedly until you get to FM or AM. (Disc will only show if there is a CD in the CD slot.) Then try pressing and holding Sel. Use the fast forward/up or fast reverse/down to get to EXT IN on the display. Then turn the tuning knob until EXT IN is selected. Press Sel again to save the setting. Now see if the EXT IN is listed when you press the SRC button. Page 13, https://www.manualslib.com/manual/81662/Jvc-Kd-G421.html?page=13#manual , shows the general procedure for setting the preferred setting mode.
I hope this helps.
Jvc firmware
If you are using adapter, KS-PD100, it is possible that new iPods wont work with this older adapter, I would recommend to connect your iPhone via AUX on the front of the unit
Attached cd player worked fine
Most CD players will have a very small hole you can fit a paper clip into and push it
in which releases the CD drive mechansim and starts opening the tray.
You may want to press the RESET button behind the faceplate first and see if rebooting
it will make it cooperate. If you dont have the detachable faceplate completely on
some of the symptons you describe could happen.
How do i use my ipod on it
If this is a cd changer type, then they have a connection that plugs in the cd changer port and straight to your ipod. Or you can get a nice little wireless fm transmitter off of ebay brand new for $1 plus shipping. You also can use the bluetooth if you have the correct options.
- Choose a Bluetooth car radio that meets your
personal style and lifestyle. Search manufacturers' Web sites that
provide customers with detailed information about Bluetooth car radios,
including price and compatibility with other wireless devices.
Step 2
Go
to a gadget or automobile shop and scan their Bluetooth-enabled car
radios. Compare the units by brand, style, functions, and features.
Check out the latest release such as a Bluetooth DVD/CD/MP3 player.
Step 3
Target
only units that fall within your budget. While you consider the price,
make sure the quality doesn't suffer. Always look for a cheaper but
competitive unit and the one that is compatible with other accessories
such as car audio speakers and CD players.
Step 4
Test
the unit before making a purchase. Make sure it is free from
malfunctions. Always buy a product with a warranty in case it develops
problems, and keep your receipts for future reference.
Unable to set the clock on jvc kd g421
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
