20 Most Recent Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire She... Questions & Answers
I have a top mount
Sorry to read about your problem, I hope this helps you out.
if you have a lite frost build up and not large amounts of ice, on your freezer coils, you may have low freon, in your unit..if you have the large amount of Ice, you may have a defrost issue.
The only thing you can do, to help correct the problems. is clean all outside coils, below or on the back of the fridge. vacuum and compressed air to clean them. and see if that helps the issue.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
1/4/2011 12:46:40 AM • Frigidaire... • Answered on Jan 04, 2011
I have a top mount Fridigaire refrigerator and the
Good day,
Recommended minimum temperature for a refrigerator to operate properly is approx. 55 degrees.
If it is colder than that where it's located, then the first problem you'll encounter is a freezer too warm.
This is by design. The thermostat that controls the whole machine is located in the fresh food compartment. As the temperature in the room approaches 35 to 40 degrees or colder, the machine will not run.
12/12/2009 8:52:35 PM • Frigidaire... • Answered on Dec 12, 2009
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
2/22/2008 3:56:16 AM • Frigidaire... • Answered on Feb 22, 2008
Frigidaire gallery series dishwasher bottom door seal keeps falling out
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
12/2/2023 7:59:45 PM • Frigidaire... • Answered on Dec 02, 2023
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on. Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer https://www.justanswer.com > Appliance Repair Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ... 1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros https://forum.appliancepartspros.com > posts > t55646... Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video https://www.appliancevideo.com > question > refrigera... Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk https://hvac-talk.com > vbb > threads > 53155-Frigidai... Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ... Domestic Refrigerator Short-Cycling Dec 4, 2020 Wiring time delay for a short cycling compressor Jun 23, 2022 Walk-in short cycles Mar 7, 2021 Walk-in compressor short cycling Oct 20, 2008 More results from hvac-talk.com
11/26/2023 9:05:58 PM • Frigidaire... • Answered on Nov 26, 2023
2answers
I have a code 56 on the panel of my Frigidaire side by side refrigerator. I unplugged the unit and plugged back in but the code is still there. None of the buttons work on the panel.
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with Check and scroll down this website to get the description way down on the webpage: https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
10/23/2023 3:50:36 PM • Frigidaire... • Answered on Oct 23, 2023
Frigidaire Countertop Ice Maker EFIC117-SS Won't Turn On
Check out the videos and also try the button hold reset.
Frigidaire Countertop Ice Maker Troubleshooting
icemakerbasics.com https://icemakerbasics.com > Troubleshooting Jun 26, 2023 - Hold/press the power button for 10 seconds · Unplug your Frigidaire ice maker. · If there's water in the reservoir, drain the water reservoir. https://www.google.com/search?q=Frigidaire+Countertop+Ice+Maker+EFIC117-SS+Won%27t+Turn+On ..
10/8/2023 8:12:42 PM • Frigidaire... • Answered on Oct 08, 2023
Frigidaire EFIC123-B-SSRED Counter Top Ice Maker parts diagram please?
No parts diagram available. It is made in China and is classed as a disposable item. https://www.google.com/search?q=Frigidaire+EFIC123-B-SSRED+parts+diagram You can try here, but a new one is less that $100.
Shop Ice Machine Replacement Parts Online
Frigidaire Appliance Parts https://www.frigidaireapplianceparts.com > Ice-Machi... Shop for Parts. With fast shipping, it's no wonder people trust Frigidaire Appliance Parts. For best results, please enter your model number. ..
8/23/2023 9:31:36 PM • Frigidaire... • Answered on Aug 23, 2023
I have an old Frigidaire freezer elite. Does the max. setting lower the temperature and the min. setting raise the temperature or the other way round?
minimum= lowest. maximum = highest. So to lower temp turn knob to minimum
8/9/2023 1:44:59 PM • Frigidaire... • Answered on Aug 09, 2023
Frigidaire refrigerator stuck on Sabbath Mode
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes. Sabbath Mode is turned ON and OFF by pressing and holding both the freezer "? Down" and refrigerator "? Up" indicators for five (5) seconds. The display shows "Sb" while in Sabbath mode https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator ..
7/14/2023 2:41:24 AM • Frigidaire... • Answered on Jul 14, 2023
2answers
The temperature of the freezer portion of my Frigidaire Gallery refrigerator is varying for no apparent reason. What are the likely causes and fixes?
check door seal or not closing correctly ---fan failure -stat /control board glitching
7/6/2023 7:48:42 PM • Frigidaire... • Answered on Jul 06, 2023
What does E6 code in Frigidaire wine fridge mean? Model FGWC5233TS
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction. To troubleshoot and resolve the E6 error code, you can try the following steps:
  1. Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
  2. Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
  3. Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
  4. If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
6/29/2023 6:36:22 AM • Frigidaire... • Answered on Jun 29, 2023
Frigidaire Gallery FGSC2335TF9 is randomly tripping the circuit breaker or breaker is tripping and shutting down the fridge.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
6/13/2023 1:11:40 PM • Frigidaire... • Answered on Jun 13, 2023
Frigidaire Side by Side Refrigerator. How to stop the loud humming noise coming from it please?
Question edited for clarity. It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below. The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem. Aug 22, 2022
Frigidaire Refrigerator Runs Loud? This May Be Why...
5/26/2023 4:50:51 PM • Frigidaire... • Answered on May 26, 2023
Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top Mount Refrigerator w/ 2 Clear Crispers, 2 Sliding Wire She... Logo
4 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
top mount
  • Refrigerators
