20 Most Recent Viking Professional Select VESO130SS Stainless Steel Oven Questions & Answers
3answers
The stickers that indicate what
I true wish there was, Viking will sell you only the panel with the writing on it, because its part of the panel. I an sorry that happened but there is not fix to it other than replacement of the panel.
Good Luck
Viking Number to verify if you like 1-888-845-4641
I am a certified servicer I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
12/29/2018 8:34:38 AM • Viking... • Answered on Dec 29, 2018
Viking profesional convection oven doesnt work
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 2. 3.Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good! 24145540-iys1iwg4rgvprz2dtg5bqcso-2-0.jpg 24145540-iys1iwg4rgvprz2dtg5bqcso-2-2.jpg 24145540-iys1iwg4rgvprz2dtg5bqcso-2-5.jpg 24145540-iys1iwg4rgvprz2dtg5bqcso-2-9.gif 24145540-iys1iwg4rgvprz2dtg5bqcso-2-14.gif 24145540-iys1iwg4rgvprz2dtg5bqcso-2-20.jpg 24145540-iys1iwg4rgvprz2dtg5bqcso-2-27.jpg 24145540-iys1iwg4rgvprz2dtg5bqcso-2-35.gif 24145540-iys1iwg4rgvprz2dtg5bqcso-2-44.jpg
5/11/2015 6:39:16 AM • Viking... • Answered on May 11, 2015
0answers
0answers
How much does a new
Be the first to answer 8/18/2011 12:06:20 AM • Viking... • Posted on Aug 18, 2011Be the first to answer
Viking oven VESO107CSS, tried to start cleaning mode, it would not start. Now the oven will not heat and the cleaning light is flashing
If your Viking oven VESO107CSS will not heat and the cleaning light is flashing, it's possible that the oven control board is experiencing a fault or malfunction. Here are some steps you can take to troubleshoot the issue:
  1. Turn off the power to the oven: Before attempting any repairs or troubleshooting, make sure the power to the oven is turned off at the circuit breaker.
  2. Check the door lock: If the oven door is not properly locked, the cleaning cycle will not start. Check to make sure the door is securely locked.
  3. Check the oven control board: The control board may be experiencing a fault or malfunction. Try resetting the control board by turning off the power to the oven for a few minutes, and then turning it back on. If this does not work, the control board may need to be replaced.
  4. Check the thermal fuse: The thermal fuse is a safety device that protects the oven from overheating. If the fuse is blown, the oven will not heat. Use a multimeter to check the continuity of the fuse, and replace it if necessary.
  5. Check the heating element: If the heating element is damaged or burnt out, the oven will not heat. Use a multimeter to check the continuity of the element, and replace it if necessary.
If none of these steps solve the issue, it's recommended to contact a qualified technician or the manufacturer's customer support for further assistance.
2/25/2023 6:46:12 PM • Viking Ovens • Answered on Feb 25, 2023
Where can II get a replacement 11 in by 16 in oven bake element with 9 inch contacts for my eaton viking model 305 vin
There are several options for obtaining a replacement oven bake element for your 11-inch by 16-inch Eaton Viking 305 Wine model with 9-inch contacts. Here are some of the options you can try:
Check if the manufacturer Eaton Viking offers a replacement element compatible with your oven model. You can check their website or contact their customer service for help.
Look online for spare parts stores for appliances. You can search online or local stores that sell oven bakeware for your oven model. Some popular online stores include Amazon, eBay, or appliance parts sites.
Contact an oven technician or servicer for assistance. A qualified technician may be able to help you find the correct replacement oven bake element for your Eaton Viking 305 Wine model.
Look for online forums or groups for appliance owners. There are online groups where homeowners discuss their experiences repairing and maintaining their appliances. You can join these groups and ask questions for help and advice on finding a replacement oven bake element for your Eaton Viking 305 Wine model.
It is important to note that you may need to provide the exact model number of your Eaton Viking oven when searching for a replacement part to ensure you get the correct part for your appliance.
2/15/2023 4:56:54 AM • Viking Ovens • Answered on Feb 15, 2023
Viking double wall oven lower oven will not self clean
lock needs to be operational safety issue holding tight wont work check alignment of lock --spring--latch clear not damaged or debris
3/29/2022 1:06:57 AM • Viking Ovens • Answered on Mar 29, 2022
Convection mode works intermittently
Model number may help you get an answer as there are many.
12/15/2021 8:24:01 AM • Viking Ovens • Answered on Dec 15, 2021
2answers
Viking French door double wall oven. Set clock and it goes to military time. How do I get it set to regular time?
This could be a control board problem rather than a clock problem.
12/7/2020 10:14:28 PM • Viking Ovens • Answered on Dec 07, 2020
Model vdsc305-4bss. Why doesn't oven door close completely?
1. Defective hinges 2. Weak hinge springs
12/7/2020 3:48:55 PM • Viking Ovens • Answered on Dec 07, 2020
2answers
Viking replacement decals / stickers: Has anyone found a reputable source of replacement decals for oven and cooktop - mine rubbed off after a few years' use, and from cleaning....)
Try www.ovenlettering.co.uk. Mark the owner will find accurate decals of your cooker confirm it with you and send you two sets plus degreaser. Follow the simple steps from the sites video instructions and voila. It is so easy and I highly recommend Mark and his product. Tell him Shaun sent you.
2/4/2019 9:10:30 PM • Viking Ovens • Answered on Feb 04, 2019
Is it normal for the cooling fan to run while my Viking oven is still heating up?
Cooling fan? Surely the fan of a fan oven is there to circulate the heat within the oven to eliminate "cold" spots and shorten cooking times. Some ovens will allow the fan to switched off.
1/8/2019 2:44:43 AM • Viking Ovens • Answered on Jan 08, 2019
Problem with Viking VGSO100SS wall oven not staying hot. Will usually light at first but once it reaches set temp and flame goes out, it will frequently have trouble re-lighting by itself
the igniter could be bad if having hard time to relite once lit should stay lit until set temp should relite automatically when needed
12/26/2018 3:42:28 PM • Viking Ovens • Answered on Dec 26, 2018
I have a Viking Oven and the code F o8 has shown up. What does that mean?
Hall effect sensor in cooling fan issue. Shut down and power up again . Or call tech assist at 888/845-4641. Hope this helps
10/16/2018 12:06:18 AM • Viking Ovens • Answered on Oct 16, 2018
My Viking electric oven will not self clean, any suggestions.
Ensure the door is closed securely if the Viking oven will not enter the self-clean cycle. If the door is not closed completely, the door lock cannot engage to start the self-cleaning. https://www.hunker.com/13408313/how-to-troubleshoot-a-viking-oven
7/29/2018 2:29:31 PM • Viking Ovens • Answered on Jul 29, 2018
Viking Professional Select VESO130SS Stainless Steel Oven Logo
7 questions posted
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Viking Oven Expert? Answer questions, earn points and help others
View Most Popular
Viking Ovens
  • Viking Ovens
Most Popular Question
stickers indicate
  • Ovens
