20 Most Recent
Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature Questions & Answers
We have a maytag oven.
only half of one side of the maytag oven touchpad control panel works, its one 2 yrs old help!
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
We had a power outage and now the oven will not
Have you checked your breaker box? It could be that the breaker for the range popped to the off position. If the breaker is still on, try carefully unplugging the range, leaving it unplugged for a few minutes, then plugging it back in.
Element broke, replaced, now oven heats very
This is a symptom of only having 120 VAC power to the oven. When your other element borke it is possible that it tripped only ONE Circuit Breaker. Try resetting the Range CB in the main power panel by physically pushing BOTH breakers to off and then back to on. Then test the range to see if it heats correctly. Let me know the result please.
Also if the problem persists respond with your model number so I can look up a wiring diagram.
Thanks for choosing FixYa,
Kelly
Oven is not working; Code F1 appears.
hello,
This
error code on a Kitchen Aid range indicates a keypad short on the
Electronic Range Control (ERC) board. This is the clock/timer on the
operator console. The recommended fix is to replace the ERC. You can
generally find replacement parts at these websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by
the average do-it-yourselfer. If you decide to order the part and wish
to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of
how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on
the circuit board. However, if the colors are not printed on the board,
write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is
the plastic pre-printed number display. The overlay can easily be
peeled off and re-used. Just make sure you properly orient the overlay
so that you don't inadvertently place it on the new board upside down.
If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize
handling the new circuit board with your bare hands to avoid damaging
the board.
thank you and thanks for using fixya.
My oven takes a very long time to warm up. Any
Mine does too ...in bake mode (45min to reach 350c) ...although broil (which I hardly use) reaches max temp in 3min ...I'm assuming the lower element has worn out and needs to be change.
