20 Most Recent Sony BRAVIA KDL-V40XBR1 Television Questions & Answers
Tv sony bravia kdl-v40xbr1 the red light flashing 7 times. tv no turn on.
May be power supply
7/2/2016 12:52:04 AM • Sony BRAVIA... • Answered on Jul 02, 2016
Unit will not power up
the lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
7/18/2013 2:14:32 PM • Sony BRAVIA... • Answered on Jul 18, 2013
0answers
How to adjust aspect ratio on sony kdl-v40xbr1
HelloTo take advantage of the wide mode feature on your TV, Set the DVD players' aspect ratio to 16:9. For details, refer the operating instructions supplied with your DVD player. Aspect ratio must be set with DVD player. Not with the TV. OK.
2/5/2012 2:03:13 PM • Sony BRAVIA... • Answered on Feb 05, 2012
2answers
I Have SONYbravia 55HX800 .
some tv are not made for all type of color system. you can read the users manual for forther details. if your tv is multisystem, u can see the menu of your color tv by pressing menu button on remote. it sould be under picture settings or under tunning settings. some set top box provide color system choice. so to get correct color you need to get setellite receiver which has option to change the color system to NTSC.
9/22/2011 12:04:35 PM • Sony BRAVIA... • Answered on Sep 22, 2011
Where it the t-con located
it is located at the upper back of your LCD TV. it has two flexible wires connected from LCD panel and one LVDS Cable from B board...
2/17/2011 3:29:21 AM • Sony BRAVIA... • Answered on Feb 17, 2011
2answers
I only see screen in
Is menu of the TV and / or on-screen display in color or black and white?
1/26/2011 5:53:14 AM • Sony BRAVIA... • Answered on Jan 26, 2011
How to change ntsc and
how to change ntsc and pal settings in a sony bravia ex400? It shows black and white color with a dvd player.
1/26/2011 5:46:13 AM • Sony BRAVIA... • Answered on Jan 26, 2011
How do i adjust the
You need a remote to goto menu and setup to adjust time and date.
1/1/2011 12:04:37 PM • Sony BRAVIA... • Answered on Jan 01, 2011
I have Sony Bravia KDL
I have looked at http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDLV40XBR1
and I would say that the UK version supports NTSC.
Lucky!!
12/24/2010 3:06:41 PM • Sony BRAVIA... • Answered on Dec 24, 2010
Green power light goes on. No picture and no
While it is unusual that the power light is steady instead of blinking a trouble code, I still believe the main power supply has failed since the failure is affecting both video and audio.
Since there are now millions of individual components in the chips used in modern sets, it may just have 'hung fire.'
You might try pulling the AC plug overnight to see if a locked-up circuit will recover without power applied.
3/7/2010 12:29:52 AM • Sony BRAVIA... • Answered on Mar 07, 2010
Broken mirror on a 50' bravia by sony
You can fix it yourself . Just measure the distance between clips to get the dimensions and most glass shops can cut you a mirror to your specs and install it yourself. A repair shop would probably be in the neighborhood of around 350 to repair it. Its just a regular mirror attached to the rear wall of your unit with screw i clips.
1/31/2008 11:35:03 PM • Sony BRAVIA... • Answered on Jan 31, 2008
Broken mirror
I would suggest to call sony and ask them for the price, if that is too expensive; measure the area where the mirror was mounted and instead of buying it from sony, go to a place where they sell mirrors and ask them to cut one for you. Just do not tell them the purpose of it because they may charge you more.
Good Luck.
1/31/2008 5:27:36 PM • Sony BRAVIA... • Answered on Jan 31, 2008
2answers
How to fix red vertical lines on my Sony Grand Vega KDS-R70 XBR
Those lines are called vertical retrace lines. There are many reasons for it. In most cases, the CRT base card board solder points should be checked for cracked or dry soldering. If you wish to get some details; check the sites linked here. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault. Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent. Just type "My service table today" in its search box, to get gathered posts published by the author of that site, about his own service experience.
10/13/2021 8:14:18 AM • Sony Televison &... • Answered on Oct 13, 2021
I need the code for my Sony DVD player model DVP-SR210P. If you can help thanks
Could be one of seven codes, so try each until one works. 20533, 21533, 20864, 21033, 21070, 21431, 21536. One of these should work if set-up directions are followed correctly.
10/5/2021 11:45:35 PM • Sony Televison &... • Answered on Oct 05, 2021
Will the power supply cord for sony bravia KDL 40ex500 work on 40ex400?
Usually manufacturers use as many standardized components as possible to reduce costs so it is highly probable that the power cord on both a 40 & 50 inch sony tv in the same series is identical.
10/2/2021 10:54:27 AM • Sony Televison &... • Answered on Oct 02, 2021
I have a Sony KDL48W650D TV that does not work and the error message is 5 blinking red lights. How can I fix it?
Sir5x mean panel error in this case panel is defective so replace the panel .panel means screen you can Easley fixed from any Sony service center thanksM Nasir
10/1/2021 6:27:48 PM • Sony Televison &... • Answered on Oct 01, 2021
Sony BRAVIA KDL-V40XBR1 Television Logo
21 questions posted
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
change ntsc
  • Televison & Video
