20 Most Recent Toshiba 65HM167 65" Projection Television Questions & Answers
What do you mean picture tube blew?
Toshiba 65HM167... | Answered on Jan 28, 2018
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses, don't use bigger than a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good.
Toshiba 65HM167... | Answered on Nov 18, 2016
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Toshiba 65HM167... | Answered on Nov 14, 2016
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Toshiba 65HM167... | Answered on Nov 04, 2016
Did you have to remove the lamp during the chip replacement? If so, did you physically touch the glass of the lamp with your skin? Oils from the skin can cause lamp failures due to hot spots that can form on the glass.
Toshiba 65HM167... | Answered on Jul 08, 2015
okay you have to make sure you close the door that the buld goes into there is a liitle micro switch that only triggers when the cover is removed it stops the tv from lighting up the bulb once you close the door and all are put back together properly the tv will come on if it dosent you need to read in between the flashing codes
Toshiba 65HM167... | Answered on Mar 21, 2015
If ur referring to the 125volt,6.3 amp fuse it is At the rear of tv, where the power cord comes out of tv. U will need to remove the bottom back panel held by +-10 screws(much easier than it sounds) u will see fuse next to where power cord attaches to circuit board. Let me know if that helps or u need pix. [email protected]
Toshiba 65HM167... | Answered on Jan 09, 2015
If you put in a generic lamp--this WILL happen. Toshiba sets do NOT like generic lamps. And vapor lamps often do not show physical signs of going bad.
Toshiba 65HM167... | Answered on May 08, 2014
Toshiba 65HM167 65" Projection Television Logo
217 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
white dots all over screen
  • Televison & Video
