20 Most Recent Fujitsu DT-12D Corded Phone Questions & Answers
Remove all phones from the system except the one which is on the main incoming line. Unplug base unit, remove batteries from the handset and then reinstate.
Does it work?
Yes: plug each unit back in one at a time, testing as you go.
No: Disconnect and put a simple phone on the line, a wired one. If that works, your line is fine, your phones aren't.
Have you paid your phone bill? They cut you off, the number is still live, but inactive.
Manual in case you need it.
GIGASET A120 USER MANUAL Pdf Download ' ManualsLib https://www.manualslib.com/manual/651632/Gigaset-Gigaset-A120.html
Gigaset A120/A120A/A220/A220A Display keys: The base station at a Pressing a key launches the function that appears above glance that key in the display. The handset at a glance Display Function when pressed 1 Charge status of the batteries: = e V U ¢... Page 2: Safety Precautions Use only the power adapter supplied, as indicated on the devices. Check the pack contents One Gigaset A120...
Lands Phones | Answered on Sep 23, 2020
Caller ID on landlines is a paid service.
Some mobiles supply the information by default.
Some people and companies withhold their numbers because they don't was callers phoning back to extensions within the business.
Lands Phones | Answered on Sep 22, 2020
You can't. The issue is with the 1471 line answering system and not your phone.
Lands Phones | Answered on Sep 20, 2020
Google
(make and model of phone) set up
Impossible for us to guess and there are so many phone systems in use.
Lands Phones | Answered on Sep 10, 2020
Here's some suggestions from the Vtech site:
If the battery(s) has been in service for more than one year....
As a rechargeable battery gets older, its ability to hold a charge decreases. If your battery has been in service for more than twelve months, it may be a good idea to replace it.
If you are replacing the battery and you need assistance, visit our Battery Finder link. If a battery for your model is unavailable, you can search the Internet using the key words cordless phone batteries for an on-line supplier. If you prefer to purchase locally, you can look for a replacement battery at your area consumer electronics retailers. It is recommended that you take your present battery with you to insure your replacement is the correct size and has the correct plug (where applicable) and specifications (for example - 3.6v 400mAh Ni-Cd). Caution when replacing batteries
If your model takes individual cells, do not use non-rechargeable batteries. Use only the recommended rechargeable batteries as prescribed in your User's Manual.
If the battery(s) has been in service for less than one year....
If the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), your handset is not dead, making it unlikely that a new battery will fix the problem. Consider the following:
Is the base unit getting power?
If your base unit is not getting power, your handset is not charging. Tip: Do not plug your Base Power Adaptor into an electrical outlet controlled by a switch (for example, a light switch on the wall or a power strip with an On/Off switch).
If your battery pack is the plug-in type, is it securely plugged into the handset?
Disconnect, and then reconnect the battery plug to ensure a good connection. In addition, make sure the battery cover is on securely.
Do you see any charge indicators on the base or handset?
Depending on your model, the handset and/or base will have indicators to let you know when the battery is charging. Check your User's Manual for details.
Remember, if the handset shows any sign of life (any lights; characters on the display screen; sounds when keys are pressed), then is not dead, making it unlikely that a new battery will fix the problem. Try the following reset procedure:
Reset your Phone
If your telephone is not operating normally, disconnect the battery(s) from the handset and disconnect power from the base. After a few minutes, connect power to the base, install the battery(s) and cradle the handset in the base to allow it to establish a link. You can now try using your phone again.
Lands Phones | Answered on Sep 08, 2020
I might be broken then and has stopped working
Lands Phones | Answered on Sep 03, 2020
You can't. There is no adjustment of the backlight.
https://cdn-media.vtechphones.com/media/p/document2/products/%7B4B5F2951-48EE-413C-9CAF-3F956892A909%7D/CS6719-2_UM_V5_20141217.pdf
Lands Phones | Answered on Sep 02, 2020
Videos and information on Android settings
https://www.google.com/search?q=LG220CM+phone+how+can+I+turn+the+ringer+on
https://www.lg.com/us/support/product/lg-LG220CM.AN10TN
Lands Phones | Answered on Sep 01, 2020
you can not it 1 at a time only
Lands Phones | Answered on Aug 27, 2020
ManualsLib has the manual for the Panasonic KX-TG8421E digital cordless answering system here: https://www.manualslib.com/manual/650444/Panasonic-Kx-Tg8421e.html . You will need to solve a Captcha if you want the manual as a PDF. The manual as a PDF is also available here: http://www.telephonesuk.co.uk/user_guides/DECT_Phones/KX-TG8421E_User_Guide_PNQX1708ZA.pdf .
I hope this helps. Note: the last digit indicates the number of handsets in the package. The E indicates where the phone system was sold.
Lands Phones | Answered on Aug 26, 2020
In the link, or you could read the manual of your mystery device.
https://www.google.com/search?q=set+up+my+phone+features
Lands Phones | Answered on Aug 25, 2020
There is no user replaceable battery in the AT&T 1725 answering system. If the unit is disconnected from power, it will hold the announcement and messages that are recorded on the digital memory. However, it will lose the current time (you'll see the CL code) and could loose the current Remote Access code. If you wish to avoid resetting the time after short power outages, you should invest in an uninterruptable power supply (UPS).
This is from the manual available at ManualsLib: https://www.manualslib.com/manual/10390/AtAndt-1725.html .
I hope this helps.
Lands Phones | Answered on Aug 24, 2020
Caller ID is a paid service. contact your telco to add it.
Lands Phones | Answered on Aug 21, 2020
Caller ID has to be enabled by your telco. It is not normally a free service, there is a small monthly charge.
Lands Phones | Answered on Aug 19, 2020
Maybe your phone is not working or is broken then
Lands Phones | Answered on Aug 17, 2020
Fujitsu DT-12D Corded Phone Logo
1 questions posted
Popular Products
Top Fujitsu Lands Phones Experts
Marvin
Marvin
k24674
Are you a Fujitsu Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Lands Phones
Most Popular Question
when using 1471 phone makes engaged tone
  • Lands Phones
