20 Most Recent Minuteman C46000-00 Self Contained Carpet Extractor Vacuum Questions & Answers
Hard water.
Minuteman... | Answered on May 06, 2014
There should be screws attached to base? Minuteman is the worst.
when you say nothing happens when you turn on the vacuum switch, does it mean there is no sign of power or light coming from the vacuum?
If yes, plug the vacuum to another out outlet. If it does not power up even after plugging in another outlet, then it means its having a power problem. It might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Good luck.
Minuteman... | Answered on Jun 29, 2011
with goop brand remover will take almost anything off without damaging the tile
Minuteman... | Answered on Feb 21, 2011
Leaking from where? The jets up front? If so you need to replace the electrical water control valve. Visit http:www.Michco.com to get a new one or assistance.
Minuteman... | Answered on Jun 08, 2010
My Minuteman c46000-00 isn't pumping any fluid through the jets. Would this be an alkaline problem, and if so, will baking soda and vinegar clear it up?
Also, where can I get a fix-it manual for this unit.
Does anyone know how old this unit might be??
Tks for your help!
Rick
Minuteman... | Answered on Apr 20, 2010
A new Brush motor is $305.02
Try these people:
http://www.michco.com/p-102421-minuteman-ambassador.aspx
MOTOR, 1/6HP 120VDC X17 831238-2
Item On Page-7-8 Ref# 128
Qty Required-1
This item replaces part#(s): 831238
  • 1-800-331-3339
  • Michigan Company Inc.
    2011 N. High St.
    Lansing, MI 48906
    Phone: (517) 484-9312 or 800-331-3339 US only Monday - Friday 8AM- 5PM EST Excluding National Holidays.
    FAX: 517-484-9836
    E-Mail: [email protected]
    Minuteman... | Answered on Apr 16, 2010
    Try these people:
    1- 800-331-3339
    [email protected]
    831238-2
    Qty Required-1
    Hi there, can you please check. is there is any fuse available or not. Is yes then check the fuse , may be that damaged. Thanks.
    Minuteman... | Answered on Feb 20, 2010
    want to sell it?
    Vacuums | Answered 2 days ago
    Minuteman C46000-00 Self Contained Carpet Extractor Vacuum Logo
    22 questions posted
    Top Minuteman Vacuums Experts
    Marvin
    Marvin
    Thatvacguy.com
    Are you a Minuteman Vacuum Expert? Answer questions, earn points and help others
    View Most Popular
    Minuteman Vacuums
    • Minuteman Vacuums
    Most Popular Question
    when turn auxilliary pump water still
    • Vacuums
