20 Most Recent Performance Teknique ICBM-772 Car Audio Amplifier Questions & Answers
Hi i have a performance
What is the model number and rated power out put and speaker impedance?
1/27/2018 3:31:23 AM • Performance... • Answered on Jan 27, 2018
As I can fix my amplifier if the music stops and changes diagnostig
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/9/2014 4:07:17 AM • Performance... • Answered on Oct 09, 2014
No problem just need advice
if you use for bass need to adjust to a 120Hz in the amp & eq
5/6/2010 10:49:37 PM • Performance... • Answered on May 06, 2010
My diagnostic light is on, md# icbm772
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
1/31/2010 7:52:02 PM • Performance... • Answered on Jan 31, 2010
I have power on my amp but no sounds out of the
Amps have to be grounded also. Ground the amp to the car/truck somewere close...
12/20/2009 1:22:18 AM • Performance... • Answered on Dec 20, 2009
I install wire from the battery to the amp ground
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
8/27/2009 8:22:59 AM • Performance... • Answered on Aug 27, 2009
How can I find a user manual for this amp?
what is the subsonic for
5/14/2009 6:18:10 AM • Performance... • Answered on May 14, 2009
0answers
Manual
Be the first to answer 11/5/2007 9:46:05 AM • Performance... • Posted on Nov 05, 2007Be the first to answer
Sub amp not working anymore
sounds like a typical case of poor conections causing the amp to fail... take the cover off of the amp. Inspect where the terminal blocks meet the circuit board. SOmetimes you can repair it sometimes its just too far fried..
9/18/2007 3:35:56 PM • Performance... • Answered on Sep 18, 2007
I'm working on a performance teknique and need help with getting some parts is it possible
IT IS NOT WHAT FIXYA DOES
9/5/2021 12:18:08 PM • Performance... • Answered on Sep 05, 2021
Performance Teknique icbm 779 I KNOW THE POWER POS N NEG FROM THE BATTERY GO BUT WHERE DOSE THE REM WIRE GO ?
That goes to your ignition switch positive. That way it has two positives. One is a constant to do things like hold memory, keep lights on, provide power to amplification circuitry. The other positive lead just tells the unit that the ignition is switched on, off, or in accessory position so your unit knows when to turn on and off. If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_4c629b5aef073a57
9/19/2017 8:08:18 PM • Performance... • Answered on Sep 19, 2017
Performance Teknique ICBM-772 Car Audio Amplifier Logo
Popular Tags
17 questions posted
Top Performance Teknique Car Audio & Video Experts
woodzowl307
Tom Chichester
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Performance Teknique Car Audio & Video
Most Popular Question
no problem just need advice
  • Car Audio & Video
