20 Most Recent Performance Teknique ICBM-774 Car Audio Amplifier Questions & Answers
Necesito el diagrama de amplificador performance tecnike para saber el valor de una resistencia
Cual, el 774? Yo lo tengo, si gustas te puedo ayudar con algo.
1/22/2024 4:45:08 AM • Performance... • Answered on Jan 22, 2024
Proction light stays on
If it stays on even when the speaker are not connected to it then the amp is fried but f it goes off when the amp is hooked up with no speakers then check the Ohm load on the amp and wire the speakers to match that but don't go below the ohm load on the amp...this site will help.... http://www.crutchfield.com/S-ApB0sVuYqNs/learn/learningcenter/car/subwoofers_wiring.html
8/22/2011 6:28:19 AM • Performance... • Answered on Aug 22, 2011
Hi I don't have sound
how do you have it wired as a 4 ch. or a 2 ch. the next thing i need to know if you have it hooked up for 8ohm 4ohm or 2ohm ? let me know
M.Woodring
5/27/2011 4:28:03 AM • Performance... • Answered on May 27, 2011
Red lightstays on no power
Sounds like something is shorting out and it is protection mode. Check that the wiring is correct and there are no bad spot on the power wires
5/25/2011 5:07:20 PM • Performance... • Answered on May 25, 2011
How to tune properly
make sure your speakers are wired to the amp with correct ohm load, turn gain, bass boost all the way down on amp, zero out your equilizer on the cd player and turn it all the way down then start raising volume on cd player., when u can start hearing music thru the subwoofers adjust the cd player volume till the sound from your subs is at its peak without any distortion. then start raising the gain on your amp till you are happy with the sound. It gives you the optimal signal strength coming from the cd player and the smoothest sound.
4/4/2011 1:23:51 PM • Performance... • Answered on Apr 04, 2011
0answers
It is almost obvious to me that the New Box is Unvented. If you went from Vented to non-Vented. there you go. The Amps and Subs should be doing the same thing. If your Sony 10's are designed for Vented they will not thump right in a NON-vented box.
2/18/2009 5:14:37 PM • Performance... • Answered on Feb 18, 2009
Power Surging Threw Subs!?
Possibly a ground loop with a poor ground connection at the head unit or the amp. Sometimes a small difference in the ground can set up something like this.
Could also be a problem with head unit.
Do you have capacitors for handling power surge needs? These could possibly be affecting this.
3/9/2008 7:39:20 PM • Performance... • Answered on Mar 09, 2008
Wiring question
Hi, If I got the specs right, your amp is a 4 channel hence the 4 RCA inputs. Probably the simplest would be to feed the 2 X RCA out of the deck to the 1 & 2 RCA in of the amp. This amp has also a line out, feed the amp's lineout back to the 3 & 4 in. This way, all four channels get same input from the deck and you will have identical power to all 4 speakers (front & rear). An afterthought is to also use the 4 outputs of the deck (since they are there anyway and it is not a good tech practice to leave outputs without load/speakers) and connect 4 mid-range or 4 smaller speakers. Hope this be of some idea/help. Post back should you need additional information. Good luck and kind regards.
9/2/2007 10:28:08 AM • Performance... • Answered on Sep 02, 2007
Especificaciones de subwoofer Icbm-8110
I respectfully suggest reading the manual that is available online and at the point of purchase for an accurate assessment.
3/12/2024 8:21:06 AM • Performance... • Answered on Mar 12, 2024
I'm working on a performance teknique and need help with getting some parts is it possible
IT IS NOT WHAT FIXYA DOES
9/5/2021 12:18:08 PM • Performance... • Answered on Sep 05, 2021
Performance Teknique icbm 779 I KNOW THE POWER POS N NEG FROM THE BATTERY GO BUT WHERE DOSE THE REM WIRE GO ?
That goes to your ignition switch positive. That way it has two positives. One is a constant to do things like hold memory, keep lights on, provide power to amplification circuitry. The other positive lead just tells the unit that the ignition is switched on, off, or in accessory position so your unit knows when to turn on and off. If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_4c629b5aef073a57
9/19/2017 8:08:18 PM • Performance... • Answered on Sep 19, 2017
Performance Teknique ICBM-774 Car Audio Amplifier Logo
Popular Tags
15 questions posted
Top Performance Teknique Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Performance Teknique Car Audio & Video
Most Popular Question
necesito el diagrama de amplificador
  • Car Audio & Video
