20 Most Recent Goodmans GMP33005 MP3 Player Questions & Answers
Drive for my goodmans GMP33005 is not appearing in My Computer
Please get it downloaded here :
www.computing.net > Forums > Drivers
For owner manual , you can get it here : www.user-guides.co.uk/.../goodmans/goodmansmp3/goodmans-mp3-player-instructions.html
Regards, Jay__GT
2/18/2011 12:35:29 PM • Goodmans... • Answered on Feb 18, 2011
When i on it a goodmans sign comes and nothing happens i have downloaded all my music what do i press
do what I did,throw the thing away!
6/10/2009 9:43:32 AM • Goodmans... • Answered on Jun 10, 2009
Headphones
Any good electronics supplier such as maplins in the UK can supply you with a 2.5mm stereo plug to 3.5 mm stereo socket adapter, which will allow you to use standard 3.5 headphones or speakers.
12/31/2008 1:51:14 AM • Goodmans... • Answered on Dec 31, 2008
Complete veg
Learn how to construct sentences for a start, and maybe throw in some punctuation rather than expecting me to read nearly 150 words with 1 full stop !! Oh, and to fix your GMP33005, turn it off, press and hold the reset button with a pin for 5 seconds then plug it into your PC. When the drive autoplays, or appears in explorer, right click on it and go to 'Format..'. This will delete everything and return it to its original state when you bought it.
9/13/2007 12:14:20 AM • Goodmans... • Answered on Sep 13, 2007
My Goodmans module 90 has a damaged record deck input socket. This 5 pin din socket is a push fix into the back panel hole. I am trying to identify the make and where I can buy a replacement.
La toma de entrada de registro de plataforma Goodmans Module 90 es una conexi?n de empuje de 5 pines. Esta toma de entrada se puede encontrar en la mayor?a de los sitios web de comercio electr?nico. Puede buscar el n?mero de parte de Goodmans Module 90 para encontrar un reemplazo. El n?mero de parte es GM-90-5P. Si necesita ayuda para encontrar un reemplazo
1/6/2023 12:40:13 AM • Goodmans Audio... • Answered on Jan 06, 2023
I wish to download a user manual for a Goodmans DAB Radio with Speaker Model GDPRDAB
Hey Here's your link to download for DLF Corporate Greens https://shivsanbuildwell.com/ https://shivsanbuildwell.com/properties/dlf-corporate-greens/
12/23/2022 9:42:15 AM • Goodmans Audio... • Answered on Dec 23, 2022
How to I connect my new secondhand Goodmans GHC35 to my flat screen TV?
Hello Kevin, to connect your Digihome TV 32 "with the Goodmans GHC35, you should see if the TV has an analog audio output, Audio Out, with two RCA connectors or with a 3.5mm Jack connector and from there with a cable, that at the tip has the connector to plug into the TV outlet and in the other two male RCA tabs to enter the GHC35 You can have on the TV, headphone output, that you could also use as audio out, the problem is that you will cut the speakers of the TV and you will always have to listen through the GHC35 If you did not have analog and digital audio output, for example fiber optic, you can use a digital to analog converter, connect an optical fiber cable to the output of the TV and enter the converter and exit the converter with an RCA-RCA cable and you connect it to the entrance of your GHC35 and there you would have the audio by Goodmans speakers I attached a link that shows you the A / D converter I hope you can listen to your TV together with the Goodmans Greetings Franco Dosil Hola Kevin, para conectar tu Digihome TV 32" con el Goodmans GHC35, deberias ver si el televisor cuenta con una salida de audio analogica, Audio Out, con dos conectores RCA o con un conector Jack de 3,5 mm y de ahi con un cable, que en la punta tiene el conector para enchufar a la salida del televisor y en la otra dos fichas RCA macho para entrar al GHC35 Puedes tener en el televisor , salida de auriculares, que tambien la podrias usar como audio out, el problema es que se va a cortar los parlantes propios del televisor y siempre tendras que escuchar a traves del GHC35 Si no tuvieras salida de audio analogica y si digital, ejemplo fibra optica, puedes utilizar un conversor digital a analogico, conectas un cable de fibra optica a la salida del televisor y la entras en el conversor y sales del conversor con un cable RCA-RCA y lo conectas a la entrada de tu GHC35 y ahi tendrias el audio por los parlantes Goodmans Te adjunto un link que te muestra el conversor A/D Espero que puedas escuchar tu TV junto con los Goodmans Saludos Franco Dosil https://www.steren.com.mx/convertidor-de-audio-digital-optico-digital-o-coaxial-digital-a-analogico-rca.html
4/26/2019 2:31:09 AM • Goodmans Audio... • Answered on Apr 26, 2019
How do I operate the Goodmans boombox CD player?
Model?
2/1/2018 7:57:40 PM • Goodmans Audio... • Answered on Feb 01, 2018
I have no sound from my DAB and fm goodmans rocka radio
I have no dad sound from my DAB and fm rocka raddio
11/7/2017 1:34:28 PM • Goodmans Audio... • Answered on Nov 07, 2017
Instruction manual for xb 15 cdg
Hi Michael Please click the link to download the Instruction Manual in PDF format. Andrew http://www.produktinfo.conrad.com/datenblaetter/325000-349999/342267-an-01-de-GOODMANS_XB15CDG_KARAOKE_SYSTEM.pdf
2/1/2017 3:13:43 PM • Goodmans Audio... • Answered on Feb 01, 2017
I have a goodmans XB 10 CDG system and it is coming up with E disc spins up but goes to E and stops
Dirt dust, scratched CD, moisture on CD lens (wait 30 minutes to see if it dries) possibly dirt on lens, which will need cleaning.
12/29/2016 1:46:20 AM • Goodmans Audio... • Answered on Dec 29, 2016
Ive got a goodmans gmp34g6
Just proves people dontvread the op question. The reset button is on the right hand edge, accessed with a pin.
9/20/2014 1:00:14 AM • Goodmans Audio... • Answered on Sep 20, 2014
Goodmans GMP33005 MP3 Player Logo
11 questions posted
Top Goodmans Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Goodmans Audio Players & Recorders
Most Popular Question
drive goodmans gmp33005 not appearing in
  • Audio Players & Recorders
