20 Most Recent Jwin JD-VD149 DVD Player Questions & Answers
I have a JWIN VD519
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
9/5/2011 6:50:15 PM • Jwin JD-VD149... • Answered on Sep 05, 2011
0answers
It is the dvd remote control it is not working ,
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
1/24/2010 5:20:05 PM • Jwin JD-VD149... • Answered on Jan 24, 2010
MY JD-VD149 DVD CONTROL IS NOT WORKING NEED TO
wherecan i buy a control jwinvd149 or a universal remote that can do the job
12/28/2009 1:43:02 PM • Jwin JD-VD149... • Answered on Dec 28, 2009
Err Disc
did you try another dvd? if yes, and still having issues, sounds like you got a defect product.
10/17/2009 8:17:11 AM • Jwin JD-VD149... • Answered on Oct 17, 2009
DVD Player displays a NO DISK msg, even when there is a disk.
Probably the laser unit is bad / defect.
7/24/2009 9:17:49 PM • Jwin JD-VD149... • Answered on Jul 24, 2009
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
2/14/2009 6:42:27 PM • Jwin JD-VD149... • Answered on Feb 14, 2009
Need a code
polal
5/14/2008 5:56:53 PM • Jwin JD-VD149... • Answered on May 14, 2008
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
1/19/2008 4:06:39 PM • Jwin JD-VD149... • Answered on Jan 19, 2008
Can you tell me which universal remote will work with my jwin DVD surround player please
Don't buy a Universal Remote, buy one that is made as a replacement for your model. That is called a Facsimile Remote. https://www.google.com/search?q=jwin+DVD+surround+player+replacement+remote The search query is 'make model replacement remote'. ..
1/22/2022 1:30:52 AM • Jwin Televison &... • Answered on Jan 22, 2022
0answers
0answers
Tv wont reset
Replace its main system control memory IC, and make an initialize. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
5/11/2013 11:03:49 AM • Jwin Televison &... • Answered on May 11, 2013
2answers
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
4/5/2012 9:46:05 PM • Jwin Televison &... • Answered on Apr 05, 2012
Jwin JD-VD149 DVD Player Logo
Popular Tags
16 questions posted
Top Jwin Televison & Video Experts
Jaime Hernandez
ray gallant
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jwin Televison & Video
Most Popular Question
playing pal system dvds
  • Televison & Video
