20 Most Recent Insignia NS-DVDR1 DVD Recorder Questions & Answers
0answers
6answers
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
1/20/2014 2:19:43 AM • Insignia... • Answered on Jan 20, 2014
My unit dosent have a remote.need possible codes,have olevia remote
Insignia is a house brand of Future Shop and Best Buy. Their parts department can likely supply the remote - that will be easier.
2/22/2012 5:02:12 AM • Insignia... • Answered on Feb 22, 2012
The unit does not play CD's or certain
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
6/1/2011 12:39:06 PM • Insignia... • Answered on Jun 01, 2011
In 2004 I purchased a
don't forget your files are still on the hard drive....you can access them by using a digital cable and connecting it directly to the hard drive.
10/23/2010 8:11:04 AM • Insignia... • Answered on Oct 23, 2010
How do i set the
Hello.
  1. press home.
  2. select setup.
  3. chose clock set.
  4. use arrows to set the date and time.
Further assistance :
NS-DVDR1 Manual
9/16/2010 11:21:15 AM • Insignia... • Answered on Sep 16, 2010
I need a program code for insignia dvd for samsung
We recommend using the scan or learning feature of your universal remote control to find a code.
7/1/2010 1:14:50 PM • Insignia... • Answered on Jul 01, 2010
2answers
I need assistance with setting
May I get the mmake and model # to help you with the set up. Also do you have the manual
4/20/2010 1:24:59 PM • Insignia... • Answered on Apr 20, 2010
Need remote control code for insignia ND-drvcr so
Many remote control codes can be found at InsigniaProducts.com. Search for your product model number and click on the Support tab.
2/5/2010 5:21:33 PM • Insignia... • Answered on Feb 05, 2010
I'm Looking for a remote
I have this remote if you are still looking for one
4/13/2009 2:22:45 AM • Insignia... • Answered on Apr 13, 2009
Insignia DVD/VCR NS-DRVCR won't read dvds
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
3/13/2009 6:31:26 PM • Insignia... • Answered on Mar 13, 2009
I cannot get the discs it records to play on any
This problem was solved by reinserting the DVD and finding Finalize on the menu. Once it was finalized, it played fine in other machines and on the computer.
Thanks,
Mags
2/23/2009 9:04:55 PM • Insignia... • Answered on Feb 23, 2009
2answers
Black & white picture
YPbPr refers to the 3 wire component cables designed for HD presentation. These would be RCA type (red, green and blue coponents). 'One" can assume that your DVD is currently set up for HD but you do not have the proper cables attached.
6/15/2008 6:57:43 PM • Insignia... • Answered on Jun 15, 2008
Insignia NR-DVDR1
just replace the dvd burner with a good one . its the same one that goes into ur computer . just make sure u get a small enouf one to fit . i did this and it works perfect sofar
5/30/2008 7:47:36 PM • Insignia... • Answered on May 30, 2008
Help with manual
To read this manual you must have Adobe Reader (free)
If you need it, use the following link and click Get Adobe Reader
http://www.adobe.com
Manual (Product Manual and Quick Setup)
http://www.insignia-products.com/pc-155-31-insignia-progressive-scan-dvd-recorder.aspx
12/24/2007 6:15:22 PM • Insignia... • Answered on Dec 24, 2007
No sound, no picture, it states no signal.
You can just buy a new remote. Test it using the smartphone front camera trick. Or it is the television that has no signal, do a Power Reset. Pull the mains plug for 5 minutes. Press and hold the power button on the set for 1 minute. Plug back in. Also check the input leads on the back for whatever is supplying the signal, Cable, Satellite, OTA, then check the Source button on the remote.
Insignia LCD TV Remote Control - NS-RC01G-09
Amazon.com https://www.amazon.com > product-reviews Find helpful customer reviews and review ratings for Insignia LCD TV Remote Control - NS-RC01G-09 at Amazon.com. Read honest and unbiased product reviews ...
INSIGNIA NS-RC01G-09 Remote Control
RemoteControls.com https://www.remotecontrols.com > product Price: $9.99 FREE SHIPPING - ALL US REMOTES ... Shipping - We receive hundreds of orders a day at RemoteControls.com. We do our best to ship them the same day you ... US$9.99
Insignia NS-RC01G09 Instruction Manual
ManualsLib https://www.manualslib.com > ... > NS-RC01G09 View and Download Insignia NS-RC01G09 instruction manual online. NS-RC01G09 remote control pdf manual download.
Replacement Remote Control for INSIGNIA NS-RC01G-09 ...
Amazon.com https://www.amazon.com > Replacement-INSIGNIA-N... Buy Replacement Remote Control for INSIGNIA NS-RC01G-09 NS-P501Q-10A NS-L42Q-10A LED HDTV TV: Electronics - Amazon.com ? FREE DELIVERY possible on eligible ... US$32.99 · ‎ In stock ..
1/23/2024 7:31:36 PM • Insignia... • Answered on Jan 23, 2024
How do I make my lodging star universal remote? Go to channel scan on my insignia t v
You did not provide proper make and model of remote and TV. Try this manual for properly program your TV URC105_Manual.pdf
1/19/2024 11:26:16 AM • Insignia... • Answered on Jan 19, 2024
Insignia NS-DVDR1 DVD Recorder Logo
Popular Tags
21 questions posted
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
sd k530su turning off progressive scan
  • Televison & Video
