20 Most Recent Denon DHT-1513BA Home Theater System Questions & Answers
Subwoofer not working
There may be an internal fuse that's blown. I'd take it to a repair facility and have them check it. Could also have a bad connection inside. Good luck!
10/11/2014 4:26:03 PM • Denon DHT-1513BA... • Answered on Oct 11, 2014
Denon receiver keeps clicking off sound
Does it do this with the spearkers unhooked?
1/14/2022 1:58:47 PM • Denon Audio... • Answered on Jan 14, 2022
3answers
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160 Ok..the procedure is easy. 1) unplug the unit and bring it to a well lit work area. 2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use. 3) re-install the board and plug in all the connections. 4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
1/9/2022 6:14:19 AM • Denon Audio... • Answered on Jan 09, 2022
Why wont power come back on the unit all the fuses are good
Have you tested the voltages at the power supply
12/25/2021 5:51:24 PM • Denon Audio... • Answered on Dec 25, 2021
2answers
Tengo un amplificador DENON AVR-600RD. solo se enciende la luz roja de stand-by. debo de reiniciarlo?? COMO SE HACE?
Everyone here speaks English, you post in Spanish :>D I have a DENON AVR-600RD amplifier. only the red stand-by light comes on. should i restart it ?? HOW IS IT DONE? https://translate.google.ca/?sl=auto&tl=en&op=translate Unplug it for 30 minutes. https://manualmachine.com/denon/avr600avr600rd/199198-service-manual/ ..
12/14/2021 7:28:23 AM • Denon Audio... • Answered on Dec 14, 2021
My Denon 1312 AVR receiver doesn't switch on
Thist could be due to a short in the amplifier or in the power supply. You can try the following: disconnect all speakers and components. Then see if the unit powers up. If it does, turn it off, connect one item at a time until the unit fails to come on. That may identify the bad component. However, it the unit never powers up when it is devoid of speakers and components, repair is going to be more tedious, possibly cost prohibitive. https://www.justanswer.com/home-theater-stereo/8uupb-hi-denon-avr-1312-receiver-just-stop-working-suddenly-check-chassi.html https://support.denon.com/
11/13/2021 5:47:04 AM • Denon Audio... • Answered on Nov 13, 2021
No sound DENON AVR-X1500H
Are the lights in the unit still working? If not it is a power issue. A lot of the vintage gear has a fuse inside that is not user replaceable. It could be the sensing circuit or an overload relay failure too. Unless you know electronic repair, have parts suppliers available and the equipment to service it, you are going to have to send it in
10/31/2021 4:48:12 PM • Denon Audio... • Answered on Oct 31, 2021
Remote for Denon UD-M50 Multi 3 CD
The original remote is the Denon RC-877, https://www.manualslib.com/manual/435735/Denon-D-M50s-D-M50-Micro-System.html?page=9#manual . Here's are two in stock third-party exact replacements for the remote: https://remotes-world.com/products/denon-hifi-ud-m50 and https://www.remote-control-world.eu/rc-for-audio-hifi-denon-c-12_351/denon-rc-877-replacement-remote-control-p-5644 . Ebay and other sites also have listing for the remote. I hope this helps. Cindy Wells
8/2/2021 10:56:19 PM • Denon Audio... • Answered on Aug 02, 2021
How to set speaker levels on Denon AVR 1804
Find the user manual on hifiengine.com: https://www.hifiengine.com/manual_library/denon/avr-1804.shtml In order to download, you'll have to make an account. This is free. The site is a very good source for user- and service manuals!!!
7/12/2021 3:08:56 PM • Denon Audio... • Answered on Jul 12, 2021
Denon DN-S3700 - Eject disc problem
you want expert opinion free LOL that does not happen .we are mostly diy fixers and do not get paid
6/25/2021 11:56:24 AM • Denon Audio... • Answered on Jun 25, 2021
I have a denon April s470h receiver and was listening to it today on a low volume when all of a sudden the volume went to the max. Turned it off by the remote and a minute later the receiver turned back on at full volume, had to unplug. Has anyone had this problem?
You will need an engineer for this. The volume control is on these machines controlled by an IC or chip. That sometimes goes faulty and needs to be replaced. They have often a great deal of pins that solder on to the board and need special tools to get them on and off.
6/5/2021 3:26:43 PM • Denon Audio... • Answered on Jun 05, 2021
I just received my new Denon AVR- x3600h 120V from amazon. When powering the receiver the power switch light is off no indication that the power supply is powering the unit. The voltage at the power cable is 120V tested be AV meter. I am worried that this unit was powered by another purchaser with 220 v before it was sold to me. If this is the case what can I do to repair it or check it etc as resending to USA is costly as I live in Saudi Arabia many thanks
If you can contact Denon to see if they have a repair centre in your part of the world. As going inside the unit would end any guarantee. If you cannot get satisfaction from them and are prepared to violate the guarantee terms, then open up and look to the power supply section. With a bit of luck the fuse might have failed. But you will have to foot the bill for all future repairs.
6/5/2021 2:38:53 PM • Denon Audio... • Answered on Jun 05, 2021
Can my denon avr589 reciever be used to get (hack) into my s-10 phone when I hook up to it to play music
only if it has bluetooth capabilities
4/29/2021 11:59:26 AM • Denon Audio... • Answered on Apr 29, 2021
Need a manuel fer denon avr589
There are several support documents for the Denon AVR-589 available on the product page: https://www.denon.com/en-us/product/av-receivers/avr-589 . The current link to the owner's manual is http://assets.denon.com/DocumentMaster/us/AVR-589-OM-E_105A.pdf . There are also Quick Start Guides. I hope this helps. Cindy Wells
4/26/2021 9:45:49 PM • Denon Audio... • Answered on Apr 26, 2021
My denon dn-c635 gives "tray error" What is wring?
Possible door timing error, slipped tooth perhaps.
4/14/2021 12:48:46 PM • Denon Audio... • Answered on Apr 14, 2021
Denon DHT-1513BA Home Theater System Logo
3 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
subwoofer not working
  • Audio Players & Recorders
