20 Most Recent Memorex MVDP1077 Portable DVD Player Questions & Answers
The panel is the most expensive portion of the unit and typically will cost more than a replacement unit. Technically, yes it can be replaced. Practically, it is not feasible due to cost. Replace the unit with a new one, it will cost less.
Dan
Memorex MVDP1077... | Answered on May 27, 2011
There may be something wrong with the sensor on the door latch. We suggest lightly pressing on the door latch to see if the message goes away. Place a disc in the player. Use extremely light pressure initially when the disc is first placed in the drive and the door closed.
Gradually increase pressure very slowly. If the issue is with the latch and sensor, the disc may spin and the message may go away. If the unit is within 90 day warranty, then Memorex or the retailer can replace it. If past warranty period, the door may be repaired at a local repair center.
Memorex MVDP1077... | Answered on Aug 23, 2010
hi sir
please go through the mini scanner which is there to read the disk or there might be something wrong in the placement of the disk please check the dvd which u r inserting it may b of diffrent software.
thank you
Memorex MVDP1077... | Answered on Jun 29, 2009
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Memorex MVDP1077... | Answered on Jan 29, 2009
Your Spectrum remote control may not contain the code. A common problem with cable systems.
Memorex... | Answered on Jul 04, 2020
First, ensure that the TV is set to the TV (either NTSC (analog) or ATSC (digital)). To do this, press the Source button until this is the highlighted source. (The Source button is the second from the left (as you face the set) on the top of the TV. There is also a source button on the remote above and to the right of the arrow keys.) Next press the Menu button (center of the arrow keys on the remote or the button just to the right of the Source button on the TV). Use the navigation arrows to navigate the menus. The Channel up/down buttons mimic those arrow keys on the remote. Press the Volume Up or right arrow to select an item. Next select Setup and go to Preset. Select this sub-menu and go to Reception. Select the item and then set the mode to TV for over-the-air. Set this to CATV for cable on the antenna RF input. Press Menu repeatedly to go back in the menu system. Return to the Preset section of the Setup menu. Navigate to the Auto Install and select this. Wait for the TV to scan all channels for either NTSC or ATSC depending on the current Source. Exit the menu and change the source to the other TV tuner. Repeat the steps to Auto Install to store channels for both the analog and digital tuners.
The manual is available from ManualsLib here: https://www.manualslib.com/manual/101765/Memorex-Mlt1912.html . See pages 5, 16 and 17 (pages 6, 17 and 18 as labeled by ManualsLib) for the screen shots and pictures of the remote control and front panel buttons for these steps.
Since there are only a few low-power NTSC stations still broadcasting, you may not find any stations when you scan for channels with NTSC as the source. Depending on the stations in your area, skipping the Auto Install step for NTSC may be appropriate. I hope this helps.
Memorex... | Answered on Jun 07, 2020
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
https://elektrotricks.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device in the search box, and hit enter to get gathered related posts. See the website either in Webview with a mobile, or by a desktop computer. Mobile view has no search box in it.
Memorex... | Answered on Jun 03, 2020
Simply plug in the adapter to the HDMI port on your TV, connect it to Wi-Fi, and let the fun begin. Compatible with Android, iOS, MAC and Windows, the adapter is easy to use and makes your connected device your remote for simple control over what you're watching. Stream on!
https://www.menards.com/main/electrical/home-electronics/small-electronics/memorex-wireless-hdmi-streaming-device/mwd38b/p-1529821700089.htm
Memorex... | Answered on Apr 24, 2020
go into tv audio and change or change input or source
Memorex... | Answered on Apr 01, 2020
Sounds like main digital board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Memorex... | Answered on Feb 28, 2020
Google (Memorex)(MLTD3222)(manual) without parens.
Memorex... | Answered on Sep 10, 2019
Memorex MVDP1077 Portable DVD Player Logo
8 questions posted
Top Memorex Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Memorex Televison & Video
Most Popular Question
portable dvd player glass
  • Televison & Video
