20 Most Recent
LaserJet 3052 All-In-One Printer Questions & Answers
You may need to purchase a scanner to get a PDF like Acrobat Reader. But if you managed to save to PDF before, try to reinstall the software and add software and choose OCR. Most of the HP PDF capablility is together with its OCR software.
LaserJet 3052...
Answered
on Dec 05, 2015
First, make sure the printer is copying perfectly, so we know whether the defect is in the scanner. If the scanner is functioning normally, the problem may be in theUSB cable. Some printers only scan with USB 2.0 cable. If this defect still continue,test in another computer because your operating system might be defective.
LaserJet 3052...
Answered
on Apr 10, 2012
open the scanner unit clean all the glasses and mirrors with lint free cloth, that they are dust free and get shinning. the problem is solved.
LaserJet 3052...
Answered
on Nov 20, 2010
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
LaserJet 3052...
Answered
on Jun 21, 2010
why not ?
if you dont just try to set settings back to factory default
or try to cold reset
if you dont know how to do let me know
LaserJet 3052...
Answered
on Dec 15, 2009
you can open the cover from backside or from the side where you installing the toner.try both the way which is easy for you .
LaserJet 3052...
Answered
on Nov 10, 2009
The jam it's talking about is in the feeder on top. Check for stuck paper, or a sensor stuck down, in the feeder area on top
LaserJet 3052...
Answered
on Aug 07, 2009
I don't know your specific printer but usually you can print out a network report or a test report on your printer via the printers own control panel. It's worth looking through the maintenance and report functions and seeing if anything within that outputs what you need.
LaserJet 3052...
Answered
on Aug 05, 2009
possible wrapped around fuser,pls check
LaserJet 3052...
Answered
on Jul 02, 2009
reformat your system so that you can install properly your HP printer, this time the system are being invaded with spywares & viruses...
LaserJet 3052...
Answered
on Jun 18, 2009
Follow
these instructions to clear the jam and replace the jam clearance component.
For the noise issue, see
here and
here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
LaserJet 3052...
Answered
on May 22, 2009
Your printer's drum must be cleaned or replaced if damaged.
LaserJet 3052...
Answered
on Aug 09, 2008
I agreed with Nancy. I was also reading reviews on https://reviewspack.com/best-presentation-clickers/ and https://www.thedailytell.com/best-laser-pointers-for-presentations/ Logitech Spotlight is most powerful pointer the R800
Laser Office...
Answered
on Sep 13, 2020
https://www.youtube.com/watch?v=ssBRM0WAY2Q
Laser Office...
Answered
on Mar 20, 2020
try unplugging it from the back, the switch might be broken.
Laser Office...
Answered
on Aug 14, 2019
A fuser error is probably caused by a thermistor (detects an overheating problem). The fuser is probably best serviced by the manufacturer as an improperly serviced fuser could lead to a fire.
Laser Office...
Answered
on May 30, 2019
