20 Most Recent Zebra TLP 2824 Printer Questions & Answers
3answers
Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
12/26/2017 2:44:19 AM • Zebra TLP 2824... • Answered on Dec 26, 2017
"NO GAP Detected" occurs after automatic configuration
Vai tomar no cu essa impressora
9/12/2014 8:44:10 PM • Zebra TLP 2824... • Answered on Sep 12, 2014
MY PRINT IS FEEDING AN EXTRA BLANK STICKER
Enable the Back feed option in Printer driver. Codabar Pvt Limited Pakistan
6/24/2014 12:18:05 PM • Zebra TLP 2824... • Answered on Jun 24, 2014
Zebra label printer cutt off prints
In printer control panel menu check the print width of the label according to the size mean to say if you have 4 inch label the print width set to maximum value if print width set minimum then cutts off the print. Codabar Pvt Limited Pakistan
6/24/2014 11:59:04 AM • Zebra TLP 2824... • Answered on Jun 24, 2014
I have zebra gc420t label printing upside down ... how do we correct?
Hi, you need to set from driver or from software driver properties. a) If you are using direct printing from a system, then(In windows), go to printer driver properties (general and advanced tabs) and find the orientation feature. If you don't have an advanced driver with advanced features, then go to www.nicelabel.cl and download it for free, selecting your printer model and brand. b) If you have a software, then you should be able to see a button in the top that says "printer properties". You can normally access the driver properties from there, then you follow the instructions from a). The only problem about that is that it is normaly for testing properties, but not necesarily will solve your problem forever... You can play winner by following a) step.
6/18/2014 11:18:07 PM • Zebra TLP 2824... • Answered on Jun 18, 2014
Out of ribbon
Then change the ribbon, my friend. You need to be more specific
5/10/2014 3:44:47 AM • Zebra TLP 2824... • Answered on May 10, 2014
0answers
2answers
Printer TLP2824 thermal printer prints too many
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
3/20/2014 7:36:51 PM • Zebra TLP 2824... • Answered on Mar 20, 2014
Printing on two labels
lets start with the basics. Do a calibration of the label to the printer : - 1/ Turn off the power 2/Press and hold the feed key 3/ Turn on power and wait for the green feed light to flash twice. 4/ Release the feed key 5/ The printer should feed and print the configuration. Now press the feed key and the label should feed and stop at the gap. If this does not work , then let me know via this page.or contact me at the link below trev thermal labels printers co uk
3/6/2014 9:09:42 AM • Zebra TLP 2824... • Answered on Mar 06, 2014
I have wristbands that are continuous without sensing mark. can i set where the print area beings and ends for each band in continous mode on zebra tlp 2824 printer
Go to "Printer Settings" and set the size/width/start/end. There will be numbers in MM that you can set everything up by.
11/26/2013 2:41:38 AM • Zebra TLP 2824... • Answered on Nov 26, 2013
My TLP 2824 has been installed on another computer
If it's setting issue, you need to turn up the darkness to make it darker prints on lines.It sounds like settings issue, remember darkness & speed combination is important.
10/21/2013 9:33:27 AM • Zebra TLP 2824... • Answered on Oct 21, 2013
I have a Zebra TLP 2824 and there is a constant amber light
You are right in thinking that the amber light means an erro, but it could be any sort of error in the syntax/printer software, or just a glitch. Also it could mean that the printer top cover is not closed properly, try pressing down firmly on the fronnt of the printer to see if it goes out. It is notunknown for the cover shut sensor to be defective so giving a constant amber light. Further help can be got by contacting www.lancerlabels.co.uk and they will talk you through the problem on the phone - no charge.
3/20/2013 8:44:01 PM • Zebra TLP 2824... • Answered on Mar 20, 2013
0answers
Zebra TLP 2824 Printer Logo
73 questions posted
Top Zebra Office Equipment & Supplies Experts
David Shaub
Marvin
Marvin
Mehandi Husain ...
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
printer tlp2824 thermal printer prints
  • Office Equipment & Supplies
