20 Most Recent
Pioneer PDP-4280HD 42 in. Plasma Television Questions & Answers
I have a Pioneer Plasma
It could be either the main or power board causing this...if your able and comfortable doing it remove the back and look for PSON on the connector legend and test the voltage on that pin, it should change when you push the power button, when I say change some sets use negative and some positive signal to tell the power board its time to come out of sleeping mode and go to work..if you see for example 6 volts with it off and it goes to 3 then the main is working or if you see 3 when its off and it goes up to 6 its also working, you want to see a change in that rail...if you see it change then the power board is bad and needs replacing
2/11/2018 5:40:05 PM •
Pioneer...
Answered
on Feb 11, 2018
My Pioneer PDP 4280HD powers off after about
looks like, it is a thermal shutdown issue. Try the following: Keep a fan and direct the air towards the bottom vent holes. Switch on the TV. Keep it on continuously for more than 2 hours and see if the TV shuts off again. If not, then it confirms Thermal shutdown. Check if you have kep any papers, cloth etc very close to TV. Keep the TV ventilated. Let there be air circulation. Here is the service manual for your set, it includes the trouble shooting guide and what the codes mean. There is a lot in here and these are not easy to come by, so look at it and you can decide if you have an issue that it covers or not. these things are not easy to diagnose over the web, but we do try. I just hate spending peoples money on repairs if I am not 100% shure of the issue.
www.elwinelectronics.com/.../Field_Service_Guide_07_rev1.2.pdf
This sounds like a heat issue because it comes back on, if it were a bad board they usually don't come back on when they fail.
3/26/2011 5:35:38 AM •
Pioneer...
Answered
on Mar 26, 2011
My Pioneer PDP-4280HD Plasma -
My research into your set and its TV Guide feature brought up two points that may be relevant:
- It apparently takes about 24 hours for the guide to load up completely. This would make it difficult to get real-time info as to whether it was working or not.
- 'TV Guide' may not work will all providers, and may not work as providers switch to digital. Have you spoken to your provider about possible compatibility?
I hope that helps
______________________
Click here for a Pioneer PDP-4280HD manual.
4/22/2010 1:45:23 AM •
Pioneer...
Answered
on Apr 22, 2010
Pioneer PDP-4280HD Manual
Model: PDP-4280HD / PDP-5080HD
Have you lost your Users Manual / Owner's Guide for your Pioneer PDP-4280HD?
Would you like a digital copy of the Owners
Manual for easy searching of terms and quick reference?
Click here to
download your pdf version of the Pioneer PDP-4280HD users guide.
A straight black line has appears about one inch
Hi my name is Roety,
I can help you with your issue ,
Sorry to say you most likely have a bad panel (screen), You can try replacing the bottom buffers if they are available, but is probably the screen
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_ab7c09ec01841771
11/14/2009 4:15:46 AM •
Pioneer...
Answered
on Nov 14, 2009
