20 Most Recent Sharp TM-150 Cellular Phone Questions & Answers
No.
Unlock usually means the phone is unlocked for different sim cards by different companies. For example, I have an ATTphone and I unlocked it for use on Tmobile network. Also, applies for taking your phone to another country to use their cellphone network providers.
Factory reset only changes the DATA of apps, user settings, phonecalls, messages, etc.
Unlock is not connected to that portion of control for factory reset.
Sharp TM-150... | Answered on Jan 15, 2013
Most phones the security code is the last four digits of your cell phone number. If that's not it, try dialing *288 and pressing 1 when prompted. This will reset your phone and then the security code should be the last four digits of the phone number. This is at least the case with MOST cell phones. If not, bring it to the nearest store location of your phone provider and they can reset it
Hope this helps
Please rate my solution!
- Frankie
Sharp TM-150... | Answered on May 07, 2011
Use unlock code to unlock your mobile...Get the unlock code here theunlockspot.com and also get the unlock instruction in the same site...
Sharp TM-150... | Answered on Jan 09, 2011
Push the reaset button around or under the battery. You might need a paper clip to reset it.
Sharp TM-150... | Answered on Dec 03, 2010
http://nds1.nokia.com/phones/files/guides/Nokia_3120_UG_en.pdf
Click on the above and read the page.
You can use this company or anyone you prefer
As it is a hard phone to unlock.
Hope i helped!
Sharp TM-150... | Answered on Dec 06, 2009
might be loose contact
Sharp TM-150... | Answered on Jan 06, 2009
Do a Factory Reset on it.
Try this
Enter '3001' to cancel out the current pin which should then reset the pin to factory default of 1234.
Help with Sharp Aquos PIN code ' AVForums
https://www.avforums.com > threads > help-with-sharp-aquos-pin-code.96...
Mar 29, 2009 - Enter '3001' to cancel out the current pin which should then reset the pin to factory default of 1234. You must log in or register to reply here.
https://www.google.com/search?client=piriform&ei=fpPlXc39N869ggeWxbCICg&q=sharp+LC32LD135k+reset&oq=sharp+LC32LD135k+reset
https://www.youtube.com/watch?v=k8FIVaBjYtQ
Sharp Cell... | Answered on Dec 02, 2019
DVD drives region settings can be changed to view DVDs from different region, but on the 4th change the DVD player will lock on the 4th region change.
The DVD player can be made region free by upgrading the firmware, if it is available, but if you make a mistake the the DVD player will be a piece of junk.
The best way to make a DVD player region free is to install a piece of software on the computer to make the DVD player region free.
Please click on this link and follow my instructions to make the DVD player region free :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Sharp Cell... | Answered on Nov 07, 2019
if this is the machine your talking about check out this link to the user manual it may have the answer.
if not then you may have broken wire/s in that display. this user manual may have contact info in it so you might ask the mfg. about the issue. good luck.
https://www.manualslib.com/manual/571166/Sharp-Fv-Db1e.html
Sharp Cell... | Answered on Sep 06, 2019
You should take it to an authorized technical center. It look's like an protective mode. Maybe some electr?nico component inside it's broken...
Sharp Cell... | Answered on Jul 14, 2019
It is very easy to do. You just follow these steps and that's it.
* Go to settings
* Go to the Privacy
* Now you will see an option "Factory Data Reset" (Click on it)
* Then Click on "Erase Everything"
after that, your device will reboot itself and it will perform an operation which will reset your data from the factory.
Sharp Cell... | Answered on Apr 11, 2019
Sharp TM-150 Cellular Phone Logo
15 questions posted
Top Sharp Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Marvin
Marvin
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sharp Cell Phones
  • Sharp Cell Phones
Most Popular Question
will factory reset unlocked att sharp fx
  • Cell Phones
