20 Most Recent Samsung SPH-M610 Cellular Phone Questions & Answers
Please click the below mentioned link to download the driver for Samsung M610:
Samsung M610 driver
After downloading this software, install it. Then you can transfer desired files to your phone.
Thank You
Samsung SPH-M610... | Answered on Nov 06, 2018
If you go to a sprint store, they have a machine in there that will transfer everything! I took my phone in there, and they got my pics, files, and everything on there. Its worth a try, but I am not sure if text messages would transfer.
Samsung SPH-M610... | Answered on Apr 23, 2014
You will have to wipe your phone of all of it's data to reset it.
I'm sorry for the inconvenience.
Samsung SPH-M610... | Answered on Sep 15, 2013
Can you supply more information please? For example, when will it not auto rotate? In certain apps? On the home screen? etc.
Samsung SPH-M610... | Answered on Feb 10, 2013
Hi
How may year use to finish this phone, please keep the battery out in 15min and check if your problem in not fix the change the battery.
Samsung SPH-M610... | Answered on Jun 17, 2011
You probably entered a master reset code.
You will need to re-pair all of your bluetooth devices.
Be wary of codes on the internet as they don't always do what they say, I don't think unless you have made a back up file that you can get your data back.
Samsung SPH-M610... | Answered on Feb 03, 2011
Hello, You may contact to your service provider Samsung SPH-M610 Unlock Code to get your code for unlocking your phone. You may visit Samsung Unlock Code site, they will provide you an accurate code with easy to follow instructions on how to unlock your phone.
Hope this is helpful.
Thanks.
Samsung SPH-M610... | Answered on Feb 02, 2011
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Samsung SPH-M610... | Answered on Jan 19, 2011
If the information was saved to the sim card. (Not all phones use sim cards)
Rylan
Samsung SPH-M610... | Answered on Dec 15, 2010
you can download this pc studio from samsung.co website for free...
Hope you will succeed....
Samsung SPH-M610... | Answered on Dec 16, 2009
Hi If your screen scrambled and now it doesn't turn on at all, then your phone is faulty, what you can do to attempt to get it to turn on is to remove the battery for 5 minutes, plug the battery back in, turn it on, if it does not turn on, then plug it to the charger and try again. if it still does not turn on, then remove the battery wait a minute, plug in the power / charger only and see if you are able to turn it on. Tell me the results of the above tests, was the phone able to turn on at all? If the phone did not turn on at all, then there is a hardware fault in the phone that is perventing it from starting up, the issue could be water, or moisture that has gotten inside the phone and it has shorted out. In order to get the phone working again it would need to be taken apart completely and inspected, special screw drivers are very likely required for the job. I would suggest that you take the phone to a local repairer if its outside of warranty and if the phone has any value to you. Get a repair estimate, and see if its worth it. If you suspect water damage then you can most likely fix this issue by taking the phone completely apart and drying all the parts with a HEAT GUN, (hair dryer won't get hot enough) On low / medium settings, less than 100'c (less than 200'f) Constantly moving the heat gun over the phone and its parts, note that the lcd display may get damaged from too much heat. if that does not fix the issue then the phone has a hardware problem that we can't diagnose over the internet I would suggest that you take it to a local repairer and see what they say about it.
Samsung SPH-M610... | Answered on Dec 09, 2009
soft reset it by removing the battery for about 15 minutes and then trying to turn it on.
have you done anything to the phone lately like drop it, try to unlock it or flash the phone with new firmware ?
Samsung SPH-M610... | Answered on Oct 27, 2009
It is usually 0000 or 1234 by default.
Samsung SPH-M610... | Answered on Oct 02, 2009
Samsung SPH-M610 Cellular Phone Logo
44 questions posted
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SPH Samsung
  • SPH Samsung
Most Popular Question
usb driver software samsung m610
  • Cell Phones
