20 Most Recent LG 42LC7D-UB Television Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
LG 42LC7D-UB... | Answered on Jun 17, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
LG 42LC7D-UB... | Answered on Dec 01, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
LG 42LC7D-UB... | Answered on Nov 07, 2015
sounds like the tv has finally broke, power board may have finnaly bit the dust, need to find some one who will work on it for you
LG 42LC7D-UB... | Answered on Mar 03, 2015
replace the sensor unit perhaps the cable is faulty
you need to use a ohm meter with beep continuity to find the issue
LG 42LC7D-UB... | Answered on Nov 30, 2014
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
LG 42LC7D-UB... | Answered on Sep 02, 2014
You will need to remove all the back screws & the back will come off
LG 42LC7D-UB... | Answered on Jun 19, 2014
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Disassemble procedure to many popular brand TVs are given with illustrations.
LG 42LC7D-UB... | Answered on May 11, 2014
Which circuit board you have replaced. Except its main power board replacement, for all other board replacements, a firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
LG 42LC7D-UB... | Answered on Apr 26, 2014
It looks like electrolyte capacitors in the power supply board are causing this problem. If you can, open the back cover, check the power supply board, you will find some bulged capacitors. Change them. Your tv should work well. If you can not do it , please consult some one qualified to do.
LG 42LC7D-UB... | Answered on Jan 09, 2014
TV has detected an error either software wise or hardware wise. Has the tv sustained trauma lately? or a power surge? needs service.
LG 42LC7D-UB... | Answered on Nov 10, 2013
LG 42LC7D-UB Television Logo
126 questions posted
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 42lc7d ub slow startup
  • Televison & Video
