20 Most Recent Sony Ericsson Walkman® W610i Cellular Phone Questions & Answers
0answers
3answers
How to lock message folder & contacts in w610i
change your mobile than
7/12/2017 4:29:57 PM • Sony Ericsson... • Answered on Jul 12, 2017
Can't switch on. .showng red light on top. battery full. .sometyms switch on. .but automaticlly turnd off. still didt swich on. .wat to do?
very simple the problem might be with ur charging slot as it easily get rusted and losses contact with the charger pin so brush out it once and start charging
8/21/2013 3:58:41 PM • Sony Ericsson... • Answered on Aug 21, 2013
2answers
How to repair keypad w610i..please help me...
goto sonyericssion care and recover your keypad
7/10/2013 8:37:35 AM • Sony Ericsson... • Answered on Jul 10, 2013
Problem with network
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
11/13/2012 8:55:32 AM • Sony Ericsson... • Answered on Nov 13, 2012
2answers
Unlocking Code
call at&t and ask for the unblock nimber and you will have to know the last four digits of your social security #
8/8/2012 12:09:22 PM • Sony Ericsson... • Answered on Aug 08, 2012
No net work coverage
1) See if you have strong signal from your signal2) Go to your menu and test the antenna for your company if has antenna in your zone.3) See for interference, in hours peak.4) Consult your company if there are some problem with the Network RNC? and what they are the are with some problem.5) Finally your phone can have problem with you RF MODULE.sincerely.
12/3/2011 6:09:33 PM • Sony Ericsson... • Answered on Dec 03, 2011
When i charge my phone it comes up with the
try to troubleshoot if the problem is on power supply or the battery.
11/8/2011 10:17:03 AM • Sony Ericsson... • Answered on Nov 08, 2011
0answers
0answers
The bluetooth of my SE W610i is turned on,but it s
its broken
7/5/2011 3:34:02 PM • Sony Ericsson... • Answered on Jul 05, 2011
My sony ericsson Headset Icon still always on the
Headset simble
6/13/2011 11:23:45 AM • Sony Ericsson... • Answered on Jun 13, 2011
My SE W610i works, but shows only white screen
Hello and Welcome to FixYa!
Woops, famous WSOD (White Screen of Death) this is all due to firmware bug you need to update the Software/Firmware of your phone, but no need to worry if you got the Data Cable of your mobile, you can solve this by yourself. I've done it many times for many SE Phones, with 100% success.
Ok, if you have got your cable, then proceed; I've attached the download link below, go there download the Update Utility, install it and then the wizard will guide you on how and when to connect your phone, its easy as 123. I am sure you will do it yourself, in case you are having any problems/questions don't forget to ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Update Utility Download Link
6/6/2011 4:53:50 PM • Sony Ericsson... • Answered on Jun 06, 2011
My Sony Ericsson w610i Problem
whats problem?
4/18/2011 7:02:58 PM • Sony Ericsson... • Answered on Apr 18, 2011
6answers
My Phone Cannot open folder games and application
to solve this problem u just have to update the sony ericson software from below link.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w610i?lc=en&cc=us
but make sure u back up all contacts files and everything before updating.
just follow the instuctons and it will be fine.
2/26/2011 8:04:45 PM • Sony Ericsson... • Answered on Feb 26, 2011
Sony 610i chariging solution
Check the voltage on your adapter using a multimeter. If low then the adapter must be checked on another similar phone or otherwise try another adapter with you phone so as to confirm.
You can also check the voltage at the battery terminals of the phone if there is low charging voltage there is fault on the board. if not the battery can also be suspected. Try to swap and confirm before you buy one.
2/21/2011 11:17:44 AM • Sony Ericsson... • Answered on Feb 21, 2011
I want to unlock a sony ericsson W610i hopefully
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
1/20/2011 7:10:54 AM • Sony Ericsson... • Answered on Jan 20, 2011
Sony Ericsson Walkman® W610i Cellular Phone Logo
108 questions posted
Top Sony Ericsson Cell Phones Experts
Muzahura Frank
Marvin
Marvin
George Etukudo
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Cell Phones
Most Popular Question
bluetooth se w610i turned but s
  • Cell Phones
