20 Most Recent Nokia 7200 Cellular Phone Questions & Answers
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Nokia 7200... | Answered on Apr 19, 2011
lcd solution
Nokia 7200... | Answered on Feb 01, 2011
i think mostly have a flexible trouble....
Nokia 7200... | Answered on Jun 12, 2010
In order to activate MMS settings you are required to call your vodacom customer care and ask them what sms you have to send in order to receive mms settings. Once you get the settings save them on your phone and make it default settings. Switch off your mobile take out your sim for 02 minutes and restart your mobile with sim inside it. Now you are ready for sending or receiving mms.
Nokia 7200... | Answered on Sep 11, 2009
The only way to remove the security code is a factory reset. You will lose all data!
Remember your password!!
Nokia Cell... | Answered on Aug 01, 2020
General Information about your Nokia 1680 unlock code
When you receive your email with your unique Nokia 1680 unlocking codes, you may see there's actually more than one code.
Depending on your model you may receive two codes for newer phones or seven codes for older Nokia models
(Please see below for some examples)
If you receive a code without the #pw+ at the beginning or EG +1# at the end, then you need to add this to the code before you enter it.
For example, if you receive 418636523456123, then the code is actually #pw+418636523456123+1# (Should normally be +1# on the end).
PLEASE NOTE
WHEN ENTERING A CODE, be very carefull, Nokia models only allow 3 attempts to enter a code, after this they will lock themselves.
When you enter a code and it returns an error code, STOP and contact us, making a note of the error exact message. If you continue it will affect your chances of a refund.
However it is worth trying to use your new SIM as some phones can falsly report a 'Code Error'
How to enter your Nokia unlocking code
Use the * (Star) Key to get the p w and + characters.
Press * key 3 times for p
Press * key 4 times for w
Press * key 2 times for +
Please note: You only have 3 attempts to enter this unlocking code.
To start with, when you turn your phone on without a SIM card you should see the message 'RESTRICTED'. If you don't see this message, turn the phone off and insert a non-accepted SIM card (ie not locked to) and carry on as normal.
Nokia Cell... | Answered on Jul 22, 2020
not the way it works here!
Unlock Nokia 1200 Phone ' Unlock Code - UnlockBase
www.unlockbase.com > unlock-phone > nokia > 1200
How to Unlock Nokia 1200? 1 - Switch ON your phone without SIM Card, 2 - Compose #PW+CODE+1# (if locked from Fido ...
Codes NOKIA 1200, how to - HardReset.info
www.hardreset.info > devices > nokia > nokia-1200 > codes
Here you can find all secret codes for NOKIA 1200. ... Unlock service provider: Insert sim, turn phone on and press vol up-arrow keys) for 3 seconds, should say ...
Nokia Cell... | Answered on Jul 09, 2020
Factory reset and lose all data is your only option.
Nokia Cell... | Answered on Jul 07, 2020
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
or::
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
HARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
Nokia Cell... | Answered on Jun 16, 2020
What unlocking code do you want?
Nokia Cell... | Answered on Jun 09, 2020
Salut, Albert pour ce sc?nario, vous aurez besoin de votre manuel de service qui contient toutes les sp?cifications de couple de serrage et un sch?ma de c?blage sur les pages arri?re, la fiche de pi?ces et le manuel du propri?taire si vous ne trouvez pas le meilleur outil que vous ayez jamais achet? pour votre Nokia, ne d?sesp?rez pas , pour seulement z?ro $ 0, vous pouvez en t?l?charger un autre. Pour plus d'informations sur votre probl?me et les pr?cieux t?l?chargements "GRATUITS" dont vous aurez besoin pour visualiser ou imprimer, veuillez cliquer sur les liens bleus ci-dessous. Bonne chance et bonne journ?e.
https://www.dell.com/support/manuals/us/en/04/xps-13-7390-laptop/xps-7390-service-manual/notes-cautions-and-warnings?guid=guid-5b8de7b7-879f-45a4-88e0-732155904029&lang=en-us
https://www.maxbhi.com/nokia-7390-spare-parts-and-accessories.html
http://www.altehandys.de/downloads/man-no-7390.pdf
Nokia Cell... | Answered on Jun 06, 2020
Nokia 7200 Cellular Phone Logo
Popular Tags
6 questions posted
Popular Products
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Zaid Anarwala
Zaid Anarwala
SANTHOSH
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
mobile showing enter puk code pin code
  • Cell Phones
