20 Most Recent
Nokia 7710 Cellular Phone Questions & Answers
Nokia 7710 not charging soulition
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Nokia 7710 keypad not working
maybe ur phone hangs because memory card of ur phone is full and numbers of data in there in ur phone. can you delete any numbers you dont need or delete messeages
7710
It means that your mobile is locked to network,unlock your nokia 7710 by unlock code and try
unlock-free and get codes and unlock your mobile instantly..
My nokia 7710 just died,
Hi, when a cell phone battery works fine as you said and the cell phone does not come on, it is usually a fault from the board of the phone which the memory of the cell phone.
When the memory of the phone dies, the phone will not be able to power up by itself..
To restore by the phone to it's normal state,you will need to power up the phone by flashing the phone memory that was died..
Flashing the phone will make the phone power on and work normal again.
You can use the below link to no the process to flash the phone ..
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Network problem solution
even after getting internet settings from the network provider and saved it and restarted the Nokia 7710 mobile as recommended , my internet is not working and and it constantly shows ' No network coverage' when the mobile service is working just fine . I also do not find the Network Settings in the Nokia 7710 phone main screen OR Control Panel to Manually set it !
Puk code for tata docomo
Dear bittu_alone2,
Kindly provide us your Tata DOCOMO details and your contact number so that we can get in touch with you.
Thanks & regards,
Customer Care,
Tata DOCOMO.
Nokia 7710 web not working
hi, have you requested service settings from your network service provider? because without it you won't be able to use your web service.
cheers
My nokia 7710 mobile is on but display showing
sometimes a very low battery will cause screen-freeze...once fully charged, remove the back cover and pull the battery out for 30 seconds and replace the batt and cover...the phone should power on.
Nokia 7710 keeps switching off as USB modem
there is a problem with you mobile jack, make sure you are not using duplicate DKU2,
try to use another cable installed on new usb port, other than earlier one.
try to use any other phone on your pc too.
I cant send message to other phones it says
It usually occurs when Message Settings are changed like
> Message center number & other settings
So you need to contact your (SIM Card) Service Provider and check the Message Settings and If they have blocked by any chance and kindly even check the balance in your mobile...
My nokia 7710 not start when start display nokia
try to format use this way
http://i34.tinypic.com/syrods.jpg
Switch-off your phone.
1. Press and hold these 3 keys; (check in pic) on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
