Okie, this would incicate possibly the thru tube is still ice up or the fill valve is bad or the ice maker is not giving voltage to the fill valve. I would start with a bad fill valve if the thru tube is clear.
It is most likely the defrost timer, the defrost elements or a leak in the door seal or a blocked drain tube leading down to a pan under the refrigerator.
Water should be removed every 8 hours with the defrost timer telling the defrost elements inside the back of freezer (and out of view) to get red hot like the parts inside a hair dryer. If temperature in freezer increased any today I would consider calling someone to either replace the timer or fix the elements. Now if the door gasket is buckled the warm air will enter condensate and also cause the same thing. If you notice a temperature increase in the freezer and fridge, it's time to act soon before the food begins to spoil, Hope this helps, Sea Breeze
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
JustAnswerhttps://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes.
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "? Down" and refrigerator "? Up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode
https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
Question edited for clarity.
It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below.
The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem.
Aug 22, 2022
