20 Most Recent Frigidaire GLEB30T8A Electric Double Oven Questions & Answers
Connie,
Found the owners manual but it was worthless didn't have the control board information.
Found the control board and it used in quite a few other makes has same functions on all the units.
So here's my best answer not your unit but is the same control board..
Sure hope this helps!?
https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/1201522L.pdf
Best to you.
Frigidaire... | Answered on Jan 28, 2018
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
Frigidaire... | Answered on Apr 17, 2015
Good Afternoon Friend,
I understand you are having electrical problems with your Frigidaire double oven, model# GLEB30T8A. I also see that this is the third time you have had a repairman out to reconnect exposed wires in your 2 and a half year old appliance. I suggest contacting the manufacturer directly. They might have some advice or might be able to point you in the right direction to having your double oven repaired for good. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 23, 2014
It may be you have a bad element. If you remove it and have a volt meter you could check a the socket for power. Also if the upper and lower elements are the same change the working one to the upper oven and see if it works. If it does you need to purchase a new element. If there is no power to the upper oven you may have a bad control ora broken wire behind the panel. I would advise you to turn off the power to the oven before pulling or changing any componets.
Frigidaire... | Answered on Mar 03, 2013
Hello, Thank You for using FixYa. I will be helping you today.F8 is a failed door lock.Try turning the power off for ten minutes and back on sometimes this will fix it,If not you may need to replace the lock after checking it to see if it failed.
Thank You and please rate my answer if it was helpful..
Frigidaire... | Answered on Jun 20, 2011
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Frigidaire... | Answered on Mar 04, 2010
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Frigidaire... | Answered on Dec 04, 2009
I replaced the relay board for the top oven (the one with thetransformer) and it works properly now. My issue was only for the topoven so you probably have to replace both relay boards since both ovenshave only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out theoven about 75% of the way out of the cabinet and easily get to theboards. Just unplugged the connections and plugged them into the newboard.
To get the oven out there are two small screws that go intobrackets inside the top oven door. Highly recommend taking the doorsoff the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burnedout and I since I already had the new board I just replaced but youmight want to check that first and see if just a solder fix gets youworking again before you spend $$ on a new board.
or try this
Most likely the thermal fuse is out for the top oven, your will have toremove the unit from the wall in order to test and replace parts. Thethermal fuse part # is AP2126993. If you need to see a parts breakdowngo to searspartsdirect website
Frigidaire... | Answered on Jun 27, 2009
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Frigidaire... | Answered on Dec 21, 2008
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
If it has been awhile since the self clean function has been used grease from cooking can build up on the inner contacts of the oven control. This would either need to be replaced or taken apart and cleaned. The self clean function should either be used more frequently or not at all,
Frigidaire Ovens | Answered on Sep 24, 2020
Try pressing and holding the Clear/Off button for 3+ seconds. The LOC indicates the control panel lock is enabled. The LOC should clear from the display. Note: if you hold the key pad for too long, the lock will reengage. From the picture of your range that you included, I believe this is the key pad button just below 7 to the right of the LCD display. There is a label in a small font just below the key pad. (The label probably is a padlock symbol and the word Controls but I can't resolve it from your picture.) Some newer Frigidaire Gallery ranges have a key pad button with a padlock symbol; this would be the correct button to press and hold on those models.
Warning: on some models, the door lock will also engage. Do not try to force the door open. Wait for 15+ seconds for the door lock mechanism to fully disengage before attempting to open the door.
I hope this helps.
Frigidaire Ovens | Answered on Jul 05, 2020
Frigidaire GLEB30T8A Electric Double Oven Logo
24 questions posted
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
baking element burned into r ncan oven
  • Ovens
