20 Most Recent Frigidaire FMT148GP Microwave Oven Questions & Answers
When this happens, a lot of the time, it is because the the old bulb burnt up violently or it was unscrewed with the power still on to the unit and if the wires on the bottom of the bulb were twisted together, it probably blew a trace off of the back of the circuit board that supplies power to te bulbs. So either need to find someone to repair the circuit board or buy a new one if you can put it in, if not, need to call a servicer to replace it. But caution, thay are not cheap!!! Always unplug you microwave BEFORE replacing the bulbs!!!!!
Frigidaire... | Answered on Oct 16, 2017
Hello friend, thank you for your post!
Based off the information you have provided you would like to know the cubic size for your Frigidaire microwave, FMT148GP. The cubic footage of this particular model is 1.4 cubic feet. Hopefully this information is helpful to you. -Matt
Frigidaire... | Answered on Jan 12, 2016
I have one same model for sale $100
Frigidaire... | Answered on Jun 17, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Frigidaire... | Answered on Feb 25, 2011
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Frigidaire... | Answered on Oct 26, 2010
Most likely causes are a blown fuse in HV area of microwave or an open thermal protector or thermal fuse.
Less likely causes are failure of various parts in the HV area.
Due to the lethal dangers inherent in microwaves, servicing of these parts is likely best left to a professional. That said, if you are technically versed I can point you in the direction of some good resources for troubleshooting and repair.
Frigidaire... | Answered on Oct 21, 2010
heatman101
Frigidaire... | Answered on Sep 30, 2010
heatman101
uop
heatman101
Frigidaire... | Answered on Sep 17, 2010
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Frigidaire... | Answered on Mar 13, 2010
Check the AC fuse in side the oven. If the fuse is ok chek the low voltage transformer . If the primary winding is open replace the transformer.
Frigidaire... | Answered on May 26, 2009
The magnetron, which is the device which creates the microwaves might have got damaged. If so, it should be replaced. Magnetron is the costliest part in a Microwave oven, check the price before before servicing it.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Frigidaire... | Answered on Apr 10, 2009
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Frigidaire... | Answered on Mar 20, 2009
Frigidaire FMT148GP Microwave Oven Logo
Popular Tags
32 questions posted
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Microwave Ovens
Most Popular Question
microwave will come but not heat
  • Microwave Ovens
