20 Most Recent Frigidaire FMV156D Microwave Oven Questions & Answers
Good Morning Paul, thank you for allowing me to assist you!
For the above-listed Frigidaire model number, FMV156D, it is not recommended to use a bulb larger than 30 watts. Your microwave does not have an option available to adjust the lights. If the light is dimmed, than more than likely your microwave is experiencing an issue with the control board, a potential wiring failure, or faulty light socket. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Frigidaire... | Answered on Nov 27, 2013
It's not a difficult do it yourself job on most ovens.
With your model number, I could have given you details including the part number.
Normally you have to separate the door panels (as shown in the photo below) and then you'll see any screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how to sepearate the panels.
You can find handy exploded views and order parts for most parts by entering your model number here.
If picture does not show up, see http://www.fixya.com/uploads/images/9F32BC4.jpg
Frigidaire... | Answered on Oct 09, 2013
Frigidaire microwave FMV156DSB. Turntable don't turn and no heat. Clock, keypad, light and fan works. The guys above looks like they right about either the door or the switches for the latch. This model does have two switches and a fusible switch. Pushing up a bit on the oven door from the bottom right corner when its closed make mine turn on if you set it to cook. Switches numbered 8(x2) on the schematic has part number 5304440026 $18.05. Fusible switch has part number 5303319559 $30.36. Have'nt changed them because it may be the door hinge is bent since the door latch is made out of plastic. Also looks like a real pain to take apart just to get to the switches. I will try to bend the door hinge to see if it fixes it. "And..now." -- Kirk, "Huh?" -- Scotty, "The doors, Mr. Scott." --Kirk, "Aye. I'm workin' on 'em."
Frigidaire... | Answered on Dec 18, 2011
Slacken off the lower hinge screws and re set the door to the correct height, then tighten them back up.
That should sort that out.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Frigidaire... | Answered on Aug 10, 2011
You will need to have the switch replaced.
Frigidaire... | Answered on Mar 11, 2011
There are three parts that will trigger this problem, the magnetron "common issue" or the high voltage capacitor and diode, if the magnetron is the problem it is cheaper to replace the microwave oven for a new one.
Frigidaire... | Answered on Mar 10, 2011
replace busted fuses on pcb board then check heater if ok.then observe unit
Frigidaire... | Answered on Mar 06, 2011
I would check the door interlock switches and condensation on the control panel
Frigidaire... | Answered on Feb 22, 2011
That would be a bad bottom door switch or its mount.
The service manual is at our site here.
Frigidaire... | Answered on Dec 07, 2010
If everything works except that it does not heat the food, then the problem is due to the magnetron circuit has failed. It is made of three parts, the magnetron (the part the generates the microwaves that heat the food), the transformer and the high voltage diode. Typical failures are the magnetron shorts out, and when the oven tries to heat the food, a loud buzzing sound can be heard. The magnetron for your oven cost more then $100 so repairing the oven is rarely cost effective. Sorry.
Frigidaire... | Answered on Nov 26, 2010
Hi and welcome to FixYa, I am Kelly. There are 4 different doors for this microwave see this link:
http://specsserver.com/CACHE/FRJVHRUTDMYQ.PDF
Item 58 is the door handle
Part numbers are:
5304440323 - - - - Handle, door, black
5304440325 - - - - Handle, door, bisque
5304440324 - - - - Handle, door, white
Stainless handle not listed.. I assume it is a black handle
This has to be one of the more expensive microwave door handles I have ever experienced.
The least expensive source I found was at sears parts direct.
5304440324 Handle door white Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440324/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440323 Handle door black Price $98.97
http://www.searspartsdirect.com/partsdirect/part-number/5304440323/0022/628?pathTaken=partSearch&filterPart=&pop=flush
5304440325 Handle door bisque Price $88.80
http://www.searspartsdirect.com/partsdirect/part-number/5304440325/0022/628?pathTaken=partSearch&filterPart=&pop=flush
Note that Item 51 of the first link (top one) is the complete door assy. Also Item 60 is the door HANDLE screws (2 ea)
Just from looking at the diagrams in the first link, it appears item 56
Frame, choke cover, inner door
must be removed to gain access to the handle screws.
I looked up many sources for the handle assembly because I had a hard time believeing the handle was so expensive. Sears was by far the cheapest source.
Thanks for choosing FixYa,
Kelly
Frigidaire... | Answered on Nov 13, 2010
I will advice you check ebay.com or amazon.com for the part needed for your device, to install it, you will need to remove the door latch and see the how the spring can be attached back, you can check the instruction book for more details.
Take care.
Frigidaire... | Answered on Nov 01, 2010
heatman101
Frigidaire... | Answered on Sep 30, 2010
Hello there:
The carousel won't turn Although the carousel is usually driven by a small motor that's unrelated to the heating function of the microwave, the microwave cabinet needs to be opened to repair it.. Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly. if not replace it and check all of the wiring to the motor with a meter to see if there is any continuity to it if not there is a problem with the motor itself or the wiring harness ok?
Frigidaire... | Answered on Sep 26, 2010
Frigidaire FMV156D Microwave Oven Logo
Popular Tags
50 questions posted
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Microwave Ovens
Most Popular Question
fan amp lights turn off
  • Microwave Ovens
