20 Most Recent Tannoy Eyris 1 Main / Stereo Speaker Questions & Answers
Replacement tweeters for Eyris 1
If any new readers are seeking the same advice, then as at Feb 2016, replacements are available from Real Electronics in the UK, 08452 307 747 - this info from the service line at Tannoy. £63.21 + VAT + delivery. Part no 7900 0621 Much of the advice above is not applicable to the Eyris, folks seem to be posting generic solutions. Unbolt the hex bolts at the rear of the tweeter assembly. With a screwdriver or similar, push the threaded rods forward to move the front portion of the tweeter housing free from the cabinet. The amount of flexibility in the cables may vary, and some users may have to remove the terminal block (hex bolts again) on the rear, and remove the acoustic wadding to gain flex in the cables. There are three terminals on the tweeter, with push-fit spade connections. Green for Earth, red/black for signal. Disconnect these, pull tweeter forward, remove threaded rods. Reassembly is the reversal of removal. Ensure all cables go in same places, etc. etc.
1/22/2022 4:06:56 PM • Tannoy Eyris 1... • Answered on Jan 22, 2022
Hello, I have the tannoy mercury v1i and I want to replace the tweeter (25 mm (1")) and I do not know how many ohms, how many watts to get for this particular speaker , suggest me please, John
Speaker impedance of 8 ohms suggests home hifi use though the stated performance is typical of a bookshelf speaker, designed to be at the "reasonable" end of the market - reasonable performance, reasonable quality, reasonable cost and suitable for a wide range of volume settings at the lower end of the scale... Constructor catalogues generally offer a wide range of loudspeaker drive units including tweeters and mostly provide pictures. If you want to avoid modifying anything simply choose one that looks like yours and then check the description fits.
2/19/2022 8:48:41 PM • Tannoy Audio... • Answered on Feb 19, 2022
One of my Tannoy R1 speakers fell from about 6 feet high. It landed on its side flat, didn’t really bounce. I hooked it up again, and yeah, sounded like it was at half power and was fuzzy. Looking inside everything looked good, connections were solid, speaker was not ripped or dented. I couldn’t find a fuse, not even sure if there is supposed to be one. What’s the best way to further troubleshoot to fix the damage?
The speakers consist of an induction coil, and a magnet attached to the cone. You have damaged something internally or the cone itself. Speakers don't have fuses unless they are powered speakers with mains input and an amplifier. You need the speaker repaired or replaced. Contact the maker https://www.tannoy.com/service.html Specs https://www.ebay.com/p/78039939 ..
12/20/2020 12:48:51 AM • Tannoy Audio... • Answered on Dec 20, 2020
Dear friends, I cannot get a replacement tweeter for the Tannoy Eyris 2 Sycamore. The company Real Electronics replied that these tweeters are no longer available. Where to order. Thank you, Ctirad.
If the company say they are no longer made, then it's unlikely you will find replacements in any electrical parts supplier. If you still want to use the unit then you will have to look around for one on places like e-bay, which might be faulty elsewhere , but have a working tweeter. A search on e-bay itself might even reveal a spare tweeter! Or a second hand that's cheap to replace the one you have. At least you will another set of spares (except tweeter of course) for the new one!
10/12/2019 9:51:30 PM • Tannoy Audio... • Answered on Oct 12, 2019
Tannoy C-8 speakers serial# 262432, any idea when made?
Two suggestions: They're old how old I can't tell I'd go to their web sight and see what you can find. Sorry that's best I can do.
12/26/2018 4:19:03 PM • Tannoy Audio... • Answered on Dec 26, 2018
I work in a church that has 4 passive speakers across the room, 3 out of 4 of them sound super muffled and n one of them sound perfect Ive tried switching power amps, there is no processing help?
I would say from your description that the tweeters are blown. Can you take the speaker that sounds good and swap it out with one that sounds bad. If you do that and the good one still sounds good. You have a tweeter problem. And they would need to be replaced.
4/3/2015 2:09:19 AM • Tannoy Audio... • Answered on Apr 03, 2015
0answers
Tannoy arena
Be the first to answer 1/14/2015 9:14:06 PM • Tannoy Audio... • Posted on Jan 14, 2015Be the first to answer
Where can I buy new tweeters for Tannoy mercury v4 speakers?
Try Parts Express website.
12/28/2014 9:43:34 AM • Tannoy Audio... • Answered on Dec 28, 2014
0answers
0answers
Tannoy
Be the first to answer 1/12/2014 12:10:09 PM • Tannoy Audio... • Posted on Jan 12, 2014Be the first to answer
Screw in pins for rear of speaker have snapped need replacede
Try maplins
1/9/2014 9:12:10 PM • Tannoy Audio... • Answered on Jan 09, 2014
Tannoy Eyris 1 Main / Stereo Speaker Logo
3 questions posted
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tannoy Audio Players & Recorders
Most Popular Question
replacement tweeters eyris 1
  • Audio Players & Recorders
