20 Most Recent
Aztech (090301) Modem Questions & Answers
Aztech DSL605EW problem internet lite bling power
First uninstall the driver.Shut down and restart.If this dont work, shut down and remove the modem.reseat it and restart the PC.If this dont work go to device manager and look for any yellow symbol on the modem properties.If any right click on it and select update driver.
Post back!
Someone just told me to try this website. I am
You need an app that will display all the wifi in the area, by power and channel. I'd suspect that you are getting interference on the same channel. Try a different channel, move the antennas around, make a directional antenna, reduce the shielding between you and the router.
Aztech homeplug 117EW model, unable to operate
Have you got any electrical work done in your place? I don't know your location o can't comment on that but here in India and in places we have 3 phase supply in every home. For your device pair to function properly they need to be on the same phase. Won't work otherwise. Try plugging both the devices in the same room where you know for sure that the plugs are on the same circuit. See how it responds.
Modem:AZTECH DSL605EW
Hi i have no
It will be lit up if there's a Ethernet Cable Connected to either of the 4 ports. If you will be using a Hardwired connection to connect the Computer to the router you will see that the light on the port where the ethernet cable is connected will lit up. However if you will be using wireless connection then it wont lit up.
Thanks for using Fixya.
