20 Most Recent Phoenix Gold XS2300 Car Audio Amplifier Questions & Answers
LPF is typically Low Pass Frequency, it puts the amp in a state where only low frequency signals will pass thru to the speakers. LPL is for Low Pass Level control, that is used on PG products that have an LPL port. Using a phone style cable and a 50k potentiometer you can control the level of the amp's output.
Phoenix Gold... • Answered on Apr 27, 2019
You have 3 sets of wire connecting to the amp (besides the rca connection), Red is power from the battery, Black is the round wire (shorter the better), lastly Blue is the remote turn on wire. Without the remote turn on, your amp will not power up regardless of the power from the battery.
RCA connectors are for your audio, it carries the noise signal to your amp from the head unit...
Phoenix Gold... • Answered on Mar 21, 2011
See manual for your amp posted here
http://download.phoenixphorum.com/Manuals/Amplifiers/XS/xs2300blk.pdf
Power is the B+ terminal, Ground is the B- terminal. The small terminal in-between them is the remote turn-on.
Phoenix Gold... • Answered on Jan 28, 2011
Possible that the audio output section is short . remove speakers and fix in the fuse to test, if itt blows out the fault must be confirmed by opening of the amp and disconnection of the power output driver.If teh fuse then stays the fault is confirmed. replace and test the speakers in this section before connecting.
Phoenix Gold... • Answered on Aug 30, 2010
Hey there newton,
Looks to be just over 300Watts. MSRP is $220.00 but they can be had for $100.00 to $150.00
Click here for a review.
Best regards
Mike
Phoenix Gold... • Answered on Aug 02, 2010
http://download.phoenixphorum.com/Manuals/Amplifiers/XS/xs4chan.pdf
Phoenix Gold... • Answered on Jun 12, 2010
Ok for best results.
1.make sure you agust the gain according to person prefrences.
2make sure you set the crossover on the amp.ok in your speakers the would probley sound best if you set the Low pass fillter at 50hz and the high pass fillter at 25khz (if you have one) or on your headunit
Hope this gets the results you want.
Alex
Phoenix Gold... • Answered on Nov 29, 2009
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Phoenix Gold... • Answered on Aug 23, 2009
there is something touching or shorting out..could be speaker wire inputs on the inside..if you have it crossed over you could have it backwords or you could have a short in your RCA's..
Phoenix Gold... • Answered on Dec 04, 2008
Request the diagram from Phoenix Gold.
Phoenix Gold Car... • Answered on Mar 23, 2021
Phoenix Gold XS2300 Car Audio Amplifier Logo
23 questions posted
Top Phoenix Gold Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tom Chichester
FastHarley
FastHarley
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Phoenix Gold Car Audio & Video
Most Popular Question
power wires 3
  • Car Audio & Video
