20 Most Recent Philips Philishave HQ7782 Electric Shaver Questions & Answers
It sounds like the charger is defective or the wrong one. There are two chargers that will physically fit your shaver but only one will work. The correct one can be found at shaveroutlet.com
https://shaveroutlet.com/norelco-philips-shaver-wall-charger-transformer-cord-p-270.html
Philips... | Answered on Feb 15, 2019
Your shaver does not have a sensor that identifies when you change the head. It is simply on a timer. Depending on your specific model, the light may simply go off after a couple of weeks or you may have to reset it with the power button. Refer to your user manual for details
Philips... | Answered on Apr 11, 2017
If you do not have the registration card then you can do it on the Philips web site. You will need the serial number to do this which you can find on the iron.
Philips... | Answered on May 14, 2014
Log on to the official web site of Philips and register your product.
http://www.support.philips.com/support/sms_page.jsp?userLanguage=en&userCountry=in
In the UK, philips norelco HQ56 replacement heads for electric shaver philips HQ6695 blades replacement parts.
That HQ56 replaces HQ55.
Philips... | Answered on Oct 29, 2013
RAZOR replacement battery 2000mAh for men electric shave philipshave philips hq7782 replacement parts.
Philips... | Answered on Sep 18, 2013
In the UK, philipshave HQ6707 charger is philips mains lead charger power cord.
Philips... | Answered on Jan 07, 2013
The problem is that the battery pack is worn out and need replaced. You will need to see if this unit has one or two batteries. You will find these batteries at shaveroutlet.com. See links below for these two types
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the item pages for helpful videos for dismantling and installing new batteries
Philips... | Answered on Jun 16, 2011
You will find parts for model HQ7740, including the charger cord and stand, at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=7740&submit=
Philips... | Answered on May 17, 2011
Hi, Robert.
I have done the recearch for you on your razor.
First, the razor model is discontinued.
Second, the replacement, solder only batteries are available, but the cost is only $4 dollars less than a new razor.
I would just go and get a new razor, as it would come with a factory warranty, and be new with all the modern attachments and features.
I hope this helps you out, and good luck to you.
Philips... | Answered on Apr 11, 2011
You will find the correct battery type at shaveroutlet.com. See link below
To replace, start by removing the lotion packet cover on the back. Remove the screw on the back near the bottom to remove the pointed bottom of the shaver. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Philips... | Answered on Mar 30, 2011
Philips Philishave HQ7782 Electric Shaver Logo
46 questions posted
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Robin
xxxxxx xxx
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Health & Beauty
Most Popular Question
philishave hq7782 runs out
  • Health & Beauty
