20 Most Recent Carrier Beverage-Air CRG74-1 Commercial Refrigerator Questions & Answers
open Evaporator fan & clean.
Carrier... | Answered on May 30, 2012
You failed to stipulate the make and model of refrigerator. Usually the information on how to remove a stuck filter is located in the owner's manual.
Here's a link from the Whirlpool website on how to remove various filters when they get stuck.
https://producthelp.whirlpool.com/Refrigeration/Full-Size_Refrigerators/Product_Info/Tips_and_Tricks/Removing_a_Stuck_Water_Filter
Carrier... | Answered on Apr 22, 2020
clean your condenser with air pressure to blow out the condenser or use spray bottle to wash down the condenser and fan blade wipe down and make sure all lint is removed from air flow passages!
Carrier... | Answered on Jan 16, 2018
replace the oil pressure transducer with a new one!
you have another leak it has to be found by an experienced person, usr nitrogen to pressurize the system to over 200 pounds pressure then check again, use squirt bottle with soapy water to find leak, if no leak to be found then the leak is where u are putting your service gauge manifold set on, the shreader vales are not setting!
Hello, Paulfreling -
I did not find a link to the manual for your Beverage-Air unit on the company web site:
https://beverage-air.com/parts-service/
(Parts & Service page, with links to manuals and videos at the bottom of the page)
I suggest you call Customer Service at Beverage-Air and talk with someone there who may be able to direct you or provide you with the right manual. See the Technical Services Department phone number at the bottom of this page:
https://beverage-air.com/customer-support/
Carrier... | Answered on Jan 14, 2018
this sounds to be a tricky kinda sensor fault , that's shutting it off , this is why it restarts when pwr is reset (resets safety shutdown) also this model is known to have control board faults due to control board being mounted right on blower housing (vibration) id have a tech ck it out they should be able to see if its a flame sense sensor or contrl board error
Carrier... | Answered on Dec 21, 2016
have a ac specialist check the charge pressure in the system
I suspect that the refrigerant gas amount is not correct and the problem is that the pressures sensors are causing it to cycle according to the fluctating pressures
Carrier... | Answered on Apr 27, 2015
hola qtal como estas, tengo un problema con un reffer de carrier modelo thinline con motor resiprocante que me da alarma al 15 y para el equipo no baja ninguna llave solo protege
Carrier... | Answered on Mar 19, 2015
Carrier Beverage-Air CRG74-1 Commercial Refrigerator Logo
Popular Tags
2 questions posted
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Dennis
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Refrigerators
Most Popular Question
evaporator fan motor bad
  • Refrigerators
