20 Most Recent Phoenix Gold Xenon-600.1 Car Audio Amplifier Questions & Answers
Check to see if the fuse is blown. If it's not, the amp is unfortunately fried. It would not be worth repairing the resistor in it
Phoenix Gold... | Answered on Apr 12, 2017
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Remember to disconnect all power including ground for about to 1/2 hour to discharge capacitors. You might get lucky and get a reset. .A thumbs up would be greatly appreciated if this answer is helpful to you. led-light-keeps-flashing-phoenix-gold-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Phoenix Gold... | Answered on Jul 02, 2015
If you had the power on, and you touched the speaker + - together, you might have just smoked your amp. The only thing you can hope for is that a fuse is blown. Other than that, you might be looking at gettin it fixed or replaced
Phoenix Gold... | Answered on Feb 02, 2011
check you have a good ground connection, make sure all wires are correctly installed and make sure it is not shorting out (ie none of the wires are in contact with one another) failing this will need more details.
Phoenix Gold... | Answered on Nov 11, 2010
wat i would do was just check all ur connections and fusses first
Phoenix Gold... | Answered on Feb 28, 2010
i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
Phoenix Gold... | Answered on Oct 02, 2008
Contact Phoenix Gold at 800.950.1449
Phoenix Gold... | Answered on Jul 17, 2008
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Phoenix Gold... | Answered on Apr 20, 2008
Sometimes problems like this are caused by tiny strands of wire in the amp. These can cause catastrophic amplifier failure. If you pull the cover off of the amp, you should be able to see the strands (if they're present). If that's not the problem, you should send the amp back to PG for repair. Before you pull the cover, completely disconnect power from the amplifier.
Phoenix Gold... | Answered on Oct 09, 2007
Request the diagram directly from Phoenix Gold.
Phoenix Gold Car... | Answered on May 05, 2019
Look up the part numbers on the components themselves. I can assure you that they are readily available from places not named PG. They are made in a factory with a bunch of diffenent Brands. If simply trying to repair the knob you may be able to use another knob from different Manufacturer if it takes the same jack for wire.
Phoenix Gold Car... | Answered on Apr 28, 2019
Probably the power is not received by the heating coil, check fuse near the power cable (inside the flap on the iron bottom), or sometimes there is fuse in the power pulg of the power chord. It is rarely that the lamp is blown
Phoenix Gold Car... | Answered on Jan 18, 2019
the entire schematic and owners manual can be found here:
http://narbi.free.fr/manuels/Amplis/Phoenix%20gold/M50.pdf
Phoenix Gold Car... | Answered on Sep 24, 2018
Phoenix Gold Xenon-600.1 Car Audio Amplifier Logo
12 questions posted
Top Phoenix Gold Car Audio & Video Experts
Jeffery Lewis
Jeffery Lewis
Tom Chichester
FastHarley
FastHarley
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Phoenix Gold Car Audio & Video
Most Popular Question
phoenix gold xenon 600 1 power problem
  • Car Audio & Video
