20 Most Recent Delfield (F18WC60) Commercial Refrigerator Questions & Answers
0answers
We have a Delfield Fridge on top, freezer on
Hello, We specialize in cooler/freezer gaskets and have a custom made gasket option that would be helpful if you cannot locate the model and serial on your unit. It's a simple process at coolergaskets.com Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets. Common Delfield profiles: 165, 221, 494, 548, 770, 802, 891, and 967 Note: If you have a hard time with this we offer a $1 gasket sample ring. Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video. Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands! I hope this helps! Matt [email protected] 855-288-2259
1/3/2014 3:05:31 PM • Delfield... • Answered on Jan 03, 2014
0answers
Delfield r2fh 2 door fridge. all 3 evaporator motors are running backwards. system appears to have been worked on before, and ideas where i could find a schematic to confirm it is wired correctly?
Hello, This is the service and installation manual for your unit click this link http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/F18%20SERIES_spm.pdf around page 20 starts the wiring diagrams for the unit. If you have any questions message me back Thank you Rick
12/2/2011 4:50:07 PM • Delfield... • Answered on Dec 02, 2011
Delfield commercial refrigerator leaks from fan
check for clogged condensate drain.
6/7/2010 2:39:48 AM • Delfield... • Answered on Jun 07, 2010
Delfield bay marie M/N 18693pt S/N 65629M
very most likely overcharged on freon. With R-409-A, you can not charge by sight glass. Do the ambient plus 30 method if it is a txv. That will get you close. If it is a cap tube, charge to an evap temp of about 20 degrees. then watch it. Make sure it makes temp and shuts off.
Hope this helps
5/2/2010 3:01:40 AM • Delfield... • Answered on May 02, 2010
Delfield model #mrr2n-s ser. 0403036101321-t ice
can not immediately locate manual.
If this unit is a cooler, check this:
Anything that can effect air flow. Fans not running or running in wrong direction.
Too much product in unit.
Thermostat set too low or stickes and unit does not shut off unit.
Possibly has a defrost timer. Most coolers do not but some do. Look for one and see if it is working. Make a mark on the face and wait 15 minutes to see if it moves.
Drain pan clogged.
Doors not closing or seals not sealing.
these are the things to check out.
5/2/2010 2:56:30 AM • Delfield... • Answered on May 02, 2010
Delfield ColdPro Refrigerator, Commercial unit,
Intermittent failure of thermostat is the most likely problem.
Check the temp sensor to make sure it is clean.
You can check for voltage coming out of the thermostat when the unit is working improperly.
If the setting is on.... say, 36, the temp is... say, 26, and there is still voltage coming from the T-stat telling the compressor and fan motors to operate, then you have a bad T-stat/sensor.
Most T-stats for that type unit do not have a separate removable sensor, its all one part with a sensor on a long tube/wire.
You can probably buy one from your local refrigeration supply warehouse for less than 35 bucks.
If it were a more consistent problem, I would say you have clogged coils or low refrigerant. But if most times it works fine, and then just randomly will not shut off, that's likely a controls thing. = T-stat.
1/2/2010 4:39:38 AM • Delfield... • Answered on Jan 02, 2010
Why is Delfield 6000XL displaying wrong temp?
try disconnecting thermistor and let run if ok replace it if not possible bad cooling unit
1/23/2022 6:38:28 AM • Delfield... • Answered on Jan 23, 2022
Need to repair a pluged cappilary tube
Your best bet is to order an OEM capillary tube and replace it. Of course this requires recovering the refrigerant. The likelihood of unplugging one is very very slim unless it is a very large bore tube.
11/21/2019 9:22:22 PM • Delfield... • Answered on Nov 21, 2019
2answers
Capillary tube freezing up but evaporator coil not getting cold on my delfield commercial ref
step 1: check the freon level via pressures or weighing in the correct amount.
9/24/2019 6:10:52 PM • Delfield... • Answered on Sep 24, 2019
Delfield Refrigerator SMRPT-S27
Any problem with it?
10/6/2018 4:24:29 PM • Delfield... • Answered on Oct 06, 2018
Drain on delfield model#sar2-2sh-216
I've used a piece of wire and hot water
9/10/2017 3:45:35 PM • Delfield... • Answered on Sep 10, 2017
Delfield (F18WC60) Commercial Refrigerator Logo
15 questions posted
Top Delfield Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Delfield Refrigerators
Most Popular Question
delfield coldpro refrigerator
  • Refrigerators
