20 Most Recent
Directed D800 Car Audio Amplifier Questions & Answers
Amp is off
check all connections and fuses make sure u have great connection on ground also check for short in remote wire
Amp is off
Check fuses 1 should be on amp other is near battery on the new wire that goes to amp. If both are good check power at main and check remote with system on. If you have power and fuses good, your amp has an internal problem and needs to go to manufacturer for repair.
I purchased a used car
Good day kvanhook!!!
That cables should be connected properly in each corresponding colors (colors by colors).
Then tell me what will happen...If that cable connection did not work just add a comment..
Thank you!!
The cords that connect into the bottom of the DVD
If you would like to have a temporary fix, I would disconnect the cables from the headrest unit, use electrical tape to cover the bare wires, and then go to Radio Shack or another hobby shop and get shrink tubing. Do not cut the shrink tubing along the length of the tube, only cut it to the size of the area that you need to cover. Then you can use a hairdryer on the highest heat to shrink the tubing down in order to cover the exposed wires.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
